Hello:
When I turn on the tv it's entire screen is black for 5 minutes. After 5 minutes or so you can see the picture, but at the bottom of the screen it has a 6 inches of black and top of the black has a thin red and green line.
Help please
Sounds as though you have a filter capacitor bad in the power supply. I strongly suggest you have it checked and repaired soon, before it burns up a transistor or regulator. The cost may be a bit high now, but will escalate to possibly a complete power supply board. If you can repair your own set, check the main power supply filter capacitors. Good luck. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Mine turns on fine, with no picture??? inputs all work for video 1 and 2, sound works, remote control work but no pic????
I have the same problem, except with my TP48E50 1996 Toshiba TV.
