My Generac G2600 portable generator has gas in the oil
This is ussually caused by a stuck float in the carb and can ussually be fixed by turning off the gas, removeing the fuel line from the carb,pulling the drain on the bottom of the carb and spraying some carb cleaner in the hose fitting. also its a good idea every time you use it to shut the gas off and let it runn till it dies. allways keep the fuel off when not in use.
