Dell 1320c printer error 093-973 "Black cartridge is either missing or not fully inserted into the printer." I've replaced cartridge with four new (known good) cartridges. I've tryed the reset button. It does not recognize the black cartridge. I own two 1320c printers and all four new black cartridges work in the other printer.
SOURCE: Blinking lights
I believe that you are talking about the photoconductor kit this needs replacing when it has reached end of like if you don't replace it you will get poor print quality and risk damaging the printer as well. Below find the lexmark web site with their quick reference guide.
Luck
http://www.lexmark.com/publications/pdfs/e230/eng/qref.pdf
SOURCE: Error Light
Make sure you shake it up when you install it too. The toner and developer may not be evenly applied in the cartridge.
Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced
