You shouldn't have a virtual ip number unless you're using a VPN to connect to the net. Check your firewalls, router, anti-virus and make sure the port yahoo msg uses isn't blocked. Yahoo messenger support site should tell you what the port address is that needs to be opened to use it. TYpically they are not blocked but a firewall or other, like router or anti-virus may be configured to block the port,.
Maybe the problem is due to slow net connection. Goto Messenger->Connection preferences and select the radio button "connect via proxy server",under that select "HTTP proxy". Then in the bottom, select your Internet connection from the dropdown menu and press ok.
I recommend checking that you have a messenger account created and you are using the most recent version of the program, which you can do both at the link above.
If all the above is fine, you may have a program blocking the messenger program such as a firewall or anti virus program. You can try creating an exception for yahoo messenger with in your firewall or anti virus program.Or alternatively, disable them to see if this resolves the problem!
delete him from your list of contacts and block all emails from his email address, I would also consider checking for malware and viruses, try uninstalling yahoo messenger after you remove him and reinstall it again.good luck
Dear User, First you need to check your firewall status whether it is blocking the yahoo messenger or not. Secondly you can check other settings in your anti-virus which may be blocking the messenger due to some clauses. You can also try a system restore if you have created a restore a point.
well maybe the yahoo messenger files are getting corrupt or maybe u have some viruses in your computer.
so step one check for viruses and remove them. step two just forget about uninstalling that yahoo messenger and just go to yahoo website and install any version you want on top of the one that you have in your computer and that should fix the issue.
Please check that your firewall is blocking the messenger. If you donot have fire wall installed then its a virus or Spy ware is blocking else the messenger is corrupted. First check firewall settings.
my yahoo messenger has been blocked
