There is a fluff filter in the bottom left hand corner behind the flap. have a small tray, like a baking tray underneath it and open the flap with a flat lever or the miele yellow key. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. when it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand. also have a look in the hole and you will see the drain pump. make sure this is free of any foreign particles and then re-screw the tap back making sure it is tight.
To avoid the smell in the unit run the machine on a few 95c washes. you can use a cleaner or just white vinegar as a cleaning agent. after every wash keep the door open for about 30 mins to let it dry out as shutting the door is then a perfect enviroment for bacteria to develop and the smell.
Also check the door seal for any foreign particles every wash.
Hope this helps.
You need to wipe the seal down with vinegar. Mold needs water to grow. Have you looked at the bottom of the dishwasher after a cycle to see if you have standing water? While you are looking clean the filter.
