I have a Frigidaire stand alone refrigerator model PLRU1777DS all of a sudden it stopped cooling. I pulled it out and made sure the coils and fan were clean.
Fan by coils underneath works fine also when I turn the inside temp control it will come on both fans inside and by coil run fine. Compressor comes after about 2 min
and runs run but will not cool the coil inside the fridge at all.Compress gets a little warm. but not real hot.
Thank you in advance
Tom.
It is just a refrig no freezer. I have removed all the shelves and back panel When I turned it on the coil inside the refrig doesn't get cold.
I put my hand on the compressor and it seems to cycle on.
Thanks
Tom
This model is just a full size refrigerator only. It does not have a freezer. It doesn't seem to cool at all.but compressor and both fans are working.
Thanks
Tom
you posted this problem under the wrong model Number
There is no coil in the refrig section......What does the coil in the freezer section look like you could have a defrost problem.. is it iced up?? this will let the freezer still work but block the airflow into the refrig section..ck that and let me know
you say it stopped cooling in both sections (refrig and Freezer) ??
MCWC50DBT model. Compressor is warm to touch, LED temp controls inside work, fan is running over coils in back. Fridge just not cooling.
Compressor not running...fan runs. I cycled thru defrost and back to cool and still not working.. I put on a hard start and still nothing.
It ohms out fine and not shorted.
Only drawing 1 amp
new refrigerator has been installed and running for more that 72 hours. the compressor has not stopped running.
compressor wont run
replaced compressor start relay about 10 months ago. It has been working fine coils clean cooling fan working. Compressor is loud but will run.
