Device drivers are specialized software that allow a computer system to interact correctly with a piece of hardware. Many device drivers come pre-installed with Windows XP, and you may have added more when installing new video cards, webcams or CD drives. Updating a device driver helps the hardware remain compatible with newer software and often fixes bugs and other performance problems. Windows XP can automatically update device drivers from the Internet using the Device Manager Utility included with the
operating system.
1. Windows XP Update:
To update the sound card driver, follow these steps:
Another Option: Download From Web Link:
http://drivers.softpedia.com/
rather doing a driver hunt
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
note: it will find all of your outdated drivers
this is a free driver solutions
which will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue
updating each driver free then restart once all of the drivers have been updated
it might take some time being free
hope this helps
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
now if its for the motherboard rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html it might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions http://download.cnet.com/drivermax/3000-18513_4-10572602.html Windows 2000/XP/Vista/7/8 free driver program http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html Windows XP/2003/Vista/Server 2008/7/8 free drivers http://www.downloadcollection.com/device_doctor.htm Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use http://www.innovative-sol.com/drivermax/ hope this helps
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
free program, paid update available
motherboared model and make?
