Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jan 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Opened door after cycle started not stuck in cycle cant clear to restart
Anonymous
Level 2:
  • Expert 311 Answers
  • Posted on Jan 29, 2010
Anonymous
Expert
Level 2:
Answers
311
Questions
Helped
69969
Points
991
I would have to assume you damaged your door lock assy. You can remove the bottom access panel and there will be a tab you can pull to manually unlock the unit hanging down from the door lock assy. This may work, if this does not work then you will have to replace the door lock assy. The unit will not clear unless the door is unlocked. You could also try to unplug the unit for 10 mins or so to see if it will manually unlock itself.
Hope this helps _MJ_
Dishwasher starts program, then few mins in pause/start button flashes "insufficient water supply". Checked all hoses and all clear. Anyone? Thank you. Glen
As soon as the waser begins the wash cycle pause, open door record water level in sump.
Close door and continue cycle until machine faults and stops.
Open door, record water level in sump.
Compare before and after. If level is low that the flapper valve that allows the water to drain is stuck open and the water is draining into the sink as the unit is washing.
To confirm, if the washer drain hose is connect to the neck of the disposal or sink drain, observe the drain after restarting the wash cycle from the beginning. If water is trickling out from the dishwasher while it is washing then it is confirmed the drain door is not closed if equipped with that configuration.
All washers have a process and hardware to drain. Some have a sepperate drain pump
Hope thisd helpd?
Jun 29, 2017 • Dishwashers
1helpful
How can I clear locking mechanism?
Only fix is to enter service mode and when you exit it should remove the stored code and allow you to restart unit. If not and you are certified you can call the Tech Line for more assistance. 1-800-662-3587. They will ask you for there account number before helping you. First enter service mode, allow auto test as it will test door locks, fill, drain, and spin functions. When you exit after this test it should allow you to restart the unit as normal. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Wash started cycle. Wife stopped it at beginning of cycle. Now washer will not start at at. Lid switch is good. Will not spin, rinse, restart wash, nothing, not even clicking.
Does unit have a reset button? If it has manual control for cycle did you try going clockwise to the start position and then restarting?
If she stopped the cycle by opening the door perhaps that switch is still stuck in an open position.
Please help me, I'm the owner of five Frigidaire appliances, Recently I used self clean cycle to clean the oven (which I have done it before). Only this time the door will not open no matter w
Thank you for your inquiry, Sam Aghajan!
I see that your Frigidaire range has went through a self-cleaning and the door will not open. It sounds like a possible issue with the door latch or control panel. I understand that you have reset your range and performed a second self-clean. I would suggest holding down the cancel/clear button for five to ten seconds. This should help to unlatch the door. You can also perform a self-clean cycle and before the cycle starts clear it out and that should help to release the door. If that does not work I would recommend contacting a professional technician to come out and repair the latch. Good luck. -Matt
1helpful
Machine stops during wash cycle full of water
object stuck in pump, drain water remove and clean pump re start
Washing machine has 1 minute left on cycle stuck door wont open programme not finished
Try the following, may work:
Press the Start/Cancel button together until all the console Led's illuminate
  1. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  2. Default screen should return. Switch off.
  3. Wait for 2 minutes to try the door. If helped click.
1helpful
2answers
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
23helpful
11answers
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
