I use a micro sd on my nokia e50, and file moving on/to computer is realised through total commander via a card reader. no problems till here, but, when i reached around 60MB free space, procedures went wrong.some message was shown, and stated smth about "cannot delete. K is write protected" -i used F6 key- then i made a backup and tried to format the card still unsuccessful. what's wrong?
You either need a card reader for the SD card or a digital camera that supports SD cards and use the camera's USB cable to connect to the computer. They also make MICRO SD card adaptors that use USB plugs to connect to that computer!
You should have 2 components with your micro SD card. The card, a small adaptor and a large adaptor. All you need to do is see what size adaptor your read needs. You place the card in the tiny slot in the adaptor and slide it in the reader. The computer will find the micro SD and install the driver to read it. Then it will give you an option to open the files. That is how 99% of them work.
You can try moving the contents of the 1 GB memory card in a new folder in the phone memory using a file explorer and after that you may remove the 1 GB card from the phone, insert the new card and move the files from phone memory to SD card. However, since there is a lot of data in the old card, moving the files to the phone memory is not recommended. The recommended way is to use a memory card reader on your PC, copy the contents from the old card to a location in your computer and then move them to the new card by simple copy/paste technique.
Please rate this solution in case you find it helpful, in case you need further support, do not rate the solution, leave a comment instead and I shall get back to you.
i forgot my password...pls help me unlocked. i have got nokia 6233with 1gb micro sd. i tried to give password for the sd card. but it doesnt worked. i tried it many times. one day my phone automatically got switched off. when i switched on the phone the sd card was locked and it was asking for the password..i tried many passwords but not able to open it.. what shall i do npw . is there any software or something to open the sd card.....anyone please help me.......Solve This! I have the same problem
hi this is rahul , i'm having 1 GB micro sd memory card for my mobile
nokia 7210supernova ..... and it is password protected ... bit actually i have
forgotton the password and now i'm using another phone ... in other
phone the memory card is not openinng its asking for password .... i
have tried also by connecting the data cable but in nokia pc suite its
showing that there is no memory card ...., i had also tried thru card
reader's but its not opening ./... is there any solution to unlock this
card without losing the data in memory card ... plz help me out ........
i
have microsd card 1gb card of kingston. it is locked & i want to
unlock my memory card without losing my data. so pls send me tips for
unlock the meemory card
unlocked it without losing my files n data...
i have a sandisk sd card and i am not able to access it as i forgot the
password..........pls help me .......neither i can format it nor using
pc suite i can solve the problum..........pls help me!
hi this is Aravind , i'm having 1 GB micro sd memory card for my mobile nokia 6233 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
i have microsd card 1gb card of kingston. it is locked & i want to unlock my memory card without losing my data. so pls send me tips for unlock the meemory card
i forgot my password...pls help me unlocked it without losing my files n data... i forgot the password of my micro sd memory card 1 gb , i don't bother about data, how to open , pl explain.
it is switched off....when on i cannot do anything....obviously
