I recently bought a 22" Samsung flat panel TV. When I try to plug the cable line into the ANT IN jack in the back of the tv, it instantly sparks & pops, and it gives you a shock. Very scary. Since no electrical voltage runs through the cable line, the problem has to be with the TV. The cable guy said something about some sort of electrical feedback, whatever that means. Any thoughts? I sent it to Samsung for repair but all they did was change the ANT IN jack (since it was fried) and it did the same thing when I tried to plug in the cable.
Call your cable company. The cable is charged with up to 60 volts AC and is usually stopped at the tap. Taps CAN pass AC if a fuse is placed in the output port of the tap. Tell the cable company what happened. They'll be out quickly to find out why the voltage is passing from them to your TV.
You have measures the cable coming in , go from the center conductor to the braided ground sheath, I really think the problem is with the cable not the TV.
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
SOURCE: HDMI outlet seems to be bad/ no picture
Main Bd part# BN94-00629F and sells for $201.00 that includes a 50.00 dud. Encompassparts.com
SOURCE: 50 inch Plasma Samsung HP-T5054 appears to have power however...
check the power inverter on the power strip. also check the caps on the board and if any of those caps have a round top it is bad and needs to be replaced. i hope this helps.
SOURCE: I cannot get my PC sound to play through my Samsung LE32457A HDTV
I hope 3.5mm to twin phono would have plugged in headphone jack of PC to get sound for TV, right?
Reduce PC volume level up to zero and increase it very little bit to get sound in TV.
TV is getting excessive sound level from headphone jack and causing mute circuit to activate to avoid any internal damage.
Testimonial: "Good advice, but didn't work. :("
