The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
SOURCE: Seiko Westminster Chime Clock; Model No. QF0020 (or QF002G)
There is a small potentiometer that the volume know is on, probably replacing the pot will fix the problem. Radio Shack has these.
SOURCE: The pendulum stopped swinging...the clock and
Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
· Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beat but not always level to function properly.
· Above is the verge with a slip clutch.
· Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
SOURCE: how to fix chimes on seiko chimming clock
When to music plays it is ok but, when the chime occures it acts like it is under water.
