SOURCE: My PS2 will not play PS2 games, but it will play PS1 games
Hi
If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact [email protected]
SOURCE: PS2 reads ps1 games but not ps2. Clicking noise
Hi Jstpd,
Boot up your PS2 with no disc in it. Press the Traingle and highlight the top selection. Press the triangle again and then press X then select ON and press X. This should turn on Diagnostics. Do not reboot the PS2, just put a PS2 disc in. This might get it reading PS2 discs again.
If this does work you can follow the procedure for cleaning below:
SOURCE: My ps3 quit playing ps3 games. It would play ps2
you had a software error, when you reset the system it re installed all the software. you got lucky had one that did that i reformated the hdd and still nothing put a disc in and it would just continuosly read the disc and nothing would ever come of it. the first set of PS3's had inferier blue ray drives and they tend to crash on the hardware end. if this happens sony has a refurb program for $150 you can send yours in and get another back that is refurbed...
Testimonial: "Thank you, it has since started doing it again. "
SOURCE: won't play ps3 games or blu-ray
lasers not workin properly.
try and give it a clean but if not your gunna ave to stump up about 50 quid for a new one.
use this video for cleaning it
http://www.youtube.com/watch?v=nSYYmYXgVl0
and while you have the drive open you might want to do this test on your laser to check if its working ok :)
http://www.youtube.com/watch?v=E2_j6P82O8Y
obviously dont bother with this if your consoles got warranty
hope this helps
SOURCE: A silver slim ps2 is unable to play certain games
Okay, are you using the original PS2? If you are then it more then likely is the age of the console. The original PS2 console actually can't play some of the games that were made after the PS2 slim was released. If your using the slim than the only thing i can advise is to try using a laser lens cleaner disc and see if that helps :)
