Computers & Internet Logo
Posted on Feb 16, 2008
My Dell Monitor isn't working....yellow light?
I just unpacked it from being in storage for six months. The screen will not light up and the light next to the power button is yellow. Ideas?
  • 2 more comments
  • jessicalacey Feb 19, 2008
    It actually ended up being the video card.....Dell is sending someone out to fix it today. Thanks
  • Anonymous May 16, 2008
    Monitor will not light up . The switch will nto come on either.
    rosalind watkins
    601-924-8535
  • skilly619 May 27, 2008
    I use my desktop regularly, and I turned it on today and it worked. But while my PC was starting up i accidentally brushed my graphics card with a piece of metal from another part of my PC. That was when my monitor's colors got messed up and it had green at 100%. I turned off my PC to try and rectify the problem, but the monitor stayed on and now it won't turn off unless I unplug it. My PC works just fine, but my monitor won't acknowledge anything i do. It won't show anything when i start my PC or turn off. The light is stuck on yellow.
  • demimo Nov 10, 2008
    I moved to a new home and set up my Dell computer weeks later. The monitor comes on green for a short second before returning to a solid yellow. This is the monitor - Dell D1728D-LS VS17X Monitor. I can press the buttons to the left and get a response, i.e. "Digital input. Self Test Feature Check" comes up and when I hold the key down long enough I get a green light on the monitor. So far, nothing.
A
Anonymous
My yellow light wont go off...all of the green buttons are lit...and I did test it on another machine...any suggestions?
A
Anonymous
A yellow light indicates no signal input. Test it on another machine.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 16, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3994
Points
6
My charger broke like six months ago and I never bought a new one. When I charged it my computer didnt want to turn on. all it does when I push the power button it turns green along with the power symbol...
  • Turn on laptop.
  • Laptop will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
3answers
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Hav a dell inspiron 530 w pentium dual core processor ... bn n storage 2 to 3 months..power up w a blue light ..yellow light inside...fans works ..no usb power.. no bios screeen or a,y start up formations...
Try opening the case and unplugging all circuit card/mem modules/cpu and re-seating them in their sockets...may be during storage that heating /cooling cycles caused connections to go bad
Have 21 inch monitor dell st2210,mi problem is everythink desapere from the screen and later come back,lock picture is in the center of the monitor al the time i have 1 year waranty i call dell speak to...
Connect the monitor to some different computer, e.g., a laptop, to verify that the monitor is working.
If not, take it back to DELL/STAPLES, and get them to check it out, or to exercise the "warranty" to get it repaired/replaced.
The monitor screen has a yellow tone to it.
try the new monitor with a different pc, if it works fine, your PC has a videocard problem..
1helpful
Dell 22' monitor Black screen Green light stays on.
well i have a dell 22'' monitor and it did exactly the same thing , turns out its a fault with the invertor drive transistors ( these power the fluro screen light ) , i'm in the uk , but i would take it straight back to walmart along with proof of purchase and tell them it dont work and ask for a repair /replacement under warranty
Can't get LG desktop to communicate with monitor
connect the monitor to the PC and restart the computer. Make sure your keyboard doesn't have any stuck keys.
Grand Canyon Tech
Grand Canyon Tech
