Question about Sharp XR-11XC DLP Projector
I just replaced the lamp in my xr-11xc sharp projector, reset the timer, and it turned on. after shut down, i tried it again, and now the standby light comes on, i hear the fan spin up, then the lamp light blinks, and it restarts the process. any ideas?
  • 2,239 Answers
The colorwheel may be bad. if it doesn't spin, the lamp won't strike. if the colorwheel is ok, replace the power supply/ballast. you can get one and do it yourself, or send it to a sharp service center. either way, try www.avsolutionsny.com. they're really good.
Posted on Jan 27, 2010
6ya staff
SOURCE:
Projector sharp XR-H325SA indicating lamp I replace tha new lamp but still indicating ineed to reset lamp timer but how?
hi,
for resetting the lamp hour do the following
1. Plug the power cord into the AC socket of the projector.
2. While simultaneously holding down MENU/HELP, ENTER and DOWN ARROW button on the projector, press STANDBY/ON on the projector.
3. "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
Jan 24, 2011 | Sharp XR-10X Multimedia Projector
Projector does not start, standby lamp and lamp indicator still remains on after replacing new lamp
Have you reset the timer?
Reset the lamp timer.
• While simultaneously holding down
MENU/HELP, ENTER and R on the projector,
• “LAMP 0000H” is displayed,
Jun 12, 2010 | Sharp XR-30X Projector
Unlock Sharp XR-10X-L Notevision Proj. says keylock function on
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
Apr 27, 2010 | Sharp XR-11XC DLP Projector
I have a Sharp XR-11xc and my bulb recently burned out. I ordered and replaced with a new lamp. It would turn on but no light would be projected. I read up on the subject and tried the reset of the lamp by...
I have the exact same problem. I've only reset the counter once though. It worked great at first, but seems to be getting worse. It's like it tries to start, just doesn't light up (maybe not warm enough???) then retries like 5 times until switching to the red light. Unplug and retry.... and eventually it does come on, and once on, all is ok. Is this just the projector trying to slowly 'break in' the new bulb since it has almost no hours?
Apr 21, 2010 | Sharp XR-11XC DLP Projector
My Sharp XR-11XC Projector died not long ago with very few hours of use. The unit will not power up nor does it show any signs of trying to. No LED lights, no fans - nada. I tested the fuse and it's...
I opened mine up hit the red reset in the front and now all good. If ur red light is blinking make sure ur lamp compartment is shut properly, if not the red light will blink and unit won't turn on.
Mar 26, 2010 | Sharp XR-11XC Multimedia Projector
Sharp xr-1x is stuck in standby mode. just
hold down the menu, enter, and down arrow buttons then press the on button. this will reset the lamp timer. if it's not working, you may have a controller issue (main board).
Dec 04, 2009 | Sharp XR-1X Multimedia Projector
I just changed the bulb in my sharp xr-11xc. it worked fine till i turned it off and now its not working again
reset the lamp timer. hold down the menu, down arrow, and enter buttons, then press power.
Nov 20, 2009 | Sharp XR-11XC Multimedia Projector
I bought a new lamp for my sharp XR-11XC. Standaby/on light is flashing and lamp light is red. TI tried two new lamp. all has the same problem. Need help, Thanks!!!
have you reset the lamp timer yet? can't remember the procedure for that one exactly often hold power and down and left arrows whilst plugging in power. Check info on instructions that came with your new lamp.
Nov 18, 2009 | Sharp Projector lamp Projector Lamp
Sharp xg-h400u projector Lamp timer reset.
plug the projector in. Do not turn it on.
hold the menu, enter, and down keys at the same time....
Press On
The map will turn on and the screen should display Lamp 0000H
Pg 54 of the xr-10x manual -- http://www.sharpusa.com/files/pro_man_PGMB56X_66X_XGMB50XL_XR11XCL_XR10XL_XR10SL.pdf
May 22, 2008 | Office Equipment & Supplies
Lamp replacement
Hi traks137
You will have to reset both the lamp and filter timer before it will change the status of this unit.
Your user manual will have all the steps in it on how to do the required resetting.
Thanks for using Fixya !
May 21, 2008 | Sharp XR-11XC Multimedia Projector
Sharp XR-11XC DLP Projector Logo
370 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
