It will start,run about 2 seconds and die,i can pull the choke out about 1/4 and it will run ,acts like its starving for gas.the tank is full of good gas.is there any adjustment on this carb.i couldn't find any?
INFO:
-Remove Carb and clean, you have a high speed fuel port clogged.
NOTE:
This would also be a good time to replace your fuel lines, Take photos before you start.
RECOMENDATIONS:
-Drain all fuel from the Saws fuel tank.
-Remove and REPLACE with a NEW spark plug.
-Remove and RELPACE with a NEW Air filter.
-With spark plug and air filter removed and fuel drained pull the starting cord many times 12 or so to ensure there is no fuel in the chamber and also check for a spark at the plug.
-RE-MIX WITH NEW FUEL your 2 cycle oil to the correct ratio in a clean fuel can. it is OK to dump some in the Saws fuel tank slosh around and dump out in an approved container for disposal.
-Hold off on putting back on the air filter until you have had it running.
Hope this Tip Helps.
R/
David
