Garmin nuvi 200W GPS Receiver Logo
Posted on Jan 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was in Tyler Tx. and could not pull up an address. A couple of days earlier I had a message show up that said something about I needed to update. Not sure what that means or how to go about it. Thanks, Vangie
Anonymous
Level 2:
  • Expert 504 Answers
  • Posted on Jan 28, 2010
Anonymous
Expert
Level 2:
Answers
504
Questions
Helped
292897
Points
921
How long has it been since you've updated the maps on the unit? You may have gotten a message stating your maps were over a year old, and recommending you update them. The address in Tyler may have been too new for the unit if the maps have not been updated recently also. If this is not the case, you should be aware that some addresses may show as being in a different city due to ZIP code status. For instance, you may know an address to be in a certain town/city, but it may show as being in a neighboring town in the unit as they share a ZIP code. If you cannot find an address in your GPS, go back to the beginning and re-enter the address. When it comes to the city, however, try, "Search All". See if this helps.
1helpful
0-83 error on onkyo tx nr 555
The 0-83 error indicates a problem with the firmware update.
Try resetting the receiver's BIOS by following these steps2:
Unplug all cables
Un-Power the receiver
Power the receiver
Before the receiver gets into the "Enter for updating" message, press Tone + CBL/SAT + ON/STANDBY. This will show you either the volume numbers or get you into settings of the receiver's speaker configuration.
Press CBL/SAT + ON/STANDBY. This will clear the BIOS and show a "Clear" message on the display. Wait until you hear a couple of clicking sounds for the receiver to turn on and off the power.
TX-NR555 Owner's Manual - Onkyo Product Support (onkyousa.com)
2answers
On C35 bizhun get error when scan to email SCAN TX FAILED JOB CANCELLED any help?
your email settings got messed up... you need to go to pagescope (web interface) by typing the ip address in your webbrouser that is connected to the network and check the scan settings to see if mybe you missed something or if something has changed....
Wireless connection - can not renew the IP address
Here's what you can do Sometimes you can simply right-click the computer icon in the task bar near the clock of your XP desktop (If this icon is present). This will go through a process of resetting your IP address.
But if you do not have this option, you can go to START>RUN and type cmd. At the command line type ipconfig /release (or winipcfg /release in earlier versions of Windows). Then hit ENTER. Next, type ipconfig /renew and you should get a new IP address from the router.
If this doesn't work, renew the IP address. You will have to nullify the IP address on the PC, then shut the computer down. Next, unplug the cable modem for a couple of minutes, then plug it back in again. Once all of the modem lights are green, power up the PC again. It should automatically renew its IP at boot.
Unplug the router, then plug it back in AFTER you plug in the modem, but before you power up the PC. The router will need to supply the PC with a new IP address. Good luck, hope this helps or gives you something to try.
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
2answers
Please help..Need manual for 1993 Roadmaster treadmill.
Check Workout warehouse. Should be able to search them online.
3answers
Trojan downloader:win32/renos.ee problem
click on the x and see if you can repair/delete the trojan. run your virus checker and eliminate the issue.
Dell pc giving blue screen -issue with recent Windows update?
Dear SherriJ:
Some time you might get this issues with the updates if they doesn't install properly or the computer turns off while instaiing updates.
However you can select last known good configuration of restore you computer to earlier time.
I would recommend you to keep the automatic updates on that will help you keep your computer in a good state.
Regards,
Mohammed
1helpful
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
