Hoveround doesn't publish the manual online. Go to their website and get the contact number to call and request a manual...usually at a fee...they ****. Next time, buy a Pride, Invacare, or whomever has the owners manuals online.
Here is the link to download a MP4 manual from Hoveround:
http://www.hoveround.com/.../MPV4-Power-Chair-Manual.pdf
SOURCE: Charging a MPV4 hoveround chair
The battery charging connector, which may appear as the female connector of a stage-quality microphone, is underneith the Joystick control arm. An external charger should have been provided by the seller, so if you don;t have one, you'llhave to contact the chir manufacturer.
SOURCE: where do i go to download the manuel for my
There are no manuals to download.The most information I can find is http://www.usatechguide.org/itemreview.php?itemid=568
i suggest dropping them a email for a manual.
SOURCE: Hoveround mpv4 does not work led flash when turned
An 8 bar flash indicates a Possible Control System Trip:
A control system trip is indicated. Make sure that all connections are secure. The connection may be broken at the junction box, or the umbillical that runs under the seat may have come loose. Check those connections as well. If that does not work, you may want to have a Hoveround Tech to come out and do a diagnosis.
SOURCE: I have plugged the Soneil battery charger into the
If your Power Wheel Chair has been sitting idle for a while, the batts may need to be completely replaced. There is a gel inside the batts that need to have a current run through them via the charger on a regualr basis otherwise it will solidify. If the charger lights are onm you have connected the charger correctly for over 24 hours and the batteries are still not showing they have been charge, there may be damaged cells which means both batteries need to be totally replaced.
