SOURCE: Network Printer Problem
Does your printer have a hard disk installed? If no it may be trying to store the print job to Ram disk. Try turning off ramdisk on the printer and also disabled mopier in the driver, (device settings?)
SOURCE: 1. unable to store job at printer. 2.
That is actually telling you that your computer doesn't have enough free space to store the print data before it sends it to the printer. Under accessories run the clean disk utility and try to free up some space. As well you can empty your recycle bin and from your web browser clean out your cache. Those will usually do the trick. You can also cause this is you are trying to print at some real super high settings that aren't needed. The printer might do it but you may not need it or even be able to see the difference past a certain quality.
SOURCE: unable to store job at printer.
- Add another Memory Dimm to the Formatter Bd you can print the config page and see how much is presently installed you can go up to 500mb.
- It is unlikely you have actually filled up the Hard drive if even installed on the printer.
- Have the Admin enlarge the print spool on the server end for that printer.
SOURCE: unable to store job at printer and insufficient
To do this delete old jobs from the printer memory to enable new jobs. In the alternative you can add to the memory stick. Thanks
Your print buffer is full in your hard drive.
Remove programs you don't use
Defrag the Hard Drive
Delete Temporary files in System Tools
