Question about Electrolux EW1000i Front Load Washer
Electrolux ewf 1435 washing machine
What means the error code E50?
  • 3 more comments
  • Anonymous May 14, 2008
    wat betekent code E50
  • Anonymous Mar 16, 2014
    Hi, I've got a Electrolux ewf 1029.the machine does not start when i press the start button but instead it clicks 3 time
  • Anonymous Mar 21, 2014
    The machine fills and drains but does not spin. The pump is clean. The program Pauses with no error code.
  • Anonymous Mar 22, 2014
    Machine works for 2 seconds then just stops. No error code displayed
  • Anonymous Mar 28, 2014
    Electrolux washing machine EWF 14811 EF2 warning on display
  • 49 Answers
I can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
What means the code E 20, the water don't go out
Posted on Aug 18, 2008
6ya staff
SOURCE:
I have an washing machine type EWF 1234 does not work and error on the screen E50 I want know the solution and how the treatement thank you
An E50 error indicates a problem with the power control board or the motor. You may be able to get additional information by starting the washer on any program except the first one. Press and hold the start/pause button then press the button 2 buttons to the left. If you see an E51 error, then the triac on the power board has failed. This usually means that both the main control board and the motor have failed.
I can't find a parts list for the EWF 1234. Please check if there is another model number on the unit and add a comment with that information.
I wish that I had better news for you.
Jul 31, 2017 | Washing Machines
How to solve e50 and e54 errors
Hi!
On Electrolux washing machines error e54 means the problem in the contact group of one of the two reverse relays. I would like to help you with the e50 error. What is your model of the washing machine?
May 12, 2017 | Washing Machines
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Feb 21, 2015 | Electrolux Washing Machines
Error code E50, what does this mean? We select programme, all the lights are on, we press start and E50 appears. What does this mean?
e50 is a motor error code.check the motor brushes are ok and check the insulation on the motor as this will give you an e50 error code.could also be a faulty wiring loom to the motor or a faulty main control pcb
E50 says the motor is overheated, they recomen you let it sit for 30min to clear.
It can be the motor power supply triac has got a short circuit or there could be no signal from the motor tachometric generator, which will uaually mean a pcb fault, or wiring to motor or even the motor. hope this helps
Dec 13, 2010 | Electrolux EW1000i Front Load Washer
A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Jul 24, 2010 | Electrolux Washing Machines
Electrolux EWF 1470 Error code E20
could be the element at fault or pressure chamber
Jan 12, 2010 | Washing Machines
Electrolux EW1000i Front Load Washer Logo
2,507 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
