Question about Belling DB90 Electric Kitchen Range
Heat not turning down on hob or ovens
BELLING DB90 ovens and hob are not responding when heat is turned down. Also where can i get new front plate that sits below heating knobs? marks are worn off....
    New Friend:
  • 3 Answers
Found this online - £101.99
Belling Stainless Steel Cooker Control Panel for DB90
http://www.espares.co.uk/part/cookers-and-hobs/belling/db90/p/1092/154/0/538873/547712/stainless-steel-cooker-co.html
Posted on Mar 18, 2010
6ya staff
SOURCE:
What can I do about the hobs overheating - when on, they are only on the highest heat and can't be turned down.
THE only solution is to replace the regulators that control the hotplates.
Could prove to be expensive.
Mar 01, 2015 | Belling Ovens
Tip
Common faults with Belling DB90 Range
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling DB90 Electric Kitchen Range
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
, push in and turn the control knob to the full on position (large flame symbol). If your hob has an ignition switch on the facia, press it in until your burner lights. • Hold the control knob in for 15 seconds then release. If the burner fails to light within this time, release the control knob and wait one minute before attempting to re-ignite.
or
Push in the control knob and after a couple of seconds press the ignition switch. • Hold the control knob in for 15 seconds then turn to desired heat, If the burner fails to light within this time, release the control knob and wait one minute before attempting to re-ignite.
Feb 03, 2018 | Belling FarmHouse 931 Gas Kitchen Range
All the temperatures have rubbed off on my belling oven,it's guesswork at mo,help please.
you fan is working in oven and there is no heat that means need new heating element check heating element that is located on back wall of oven covered with metal plate belling elements can be found on website click link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
Nov 17, 2012 | Ovens
The main oven has stopped working. The fan works and the Small oven also works.
There could be a few different things wrong. The element may have died. Is the fan you mention the forced air fan? No heat usually means blown fuse or faulty heating element, and since the small oven works I would suspect the the element has blown. You would benefit from getting an appliance serviceman to make a house call to replace the element. Unless you're handy and have a soldering iron, some heat resistant sleeving, and can access the back of the oven comfortably.
Hope this helps. Let me know.
John
May 08, 2009 | Belling DB90 Electric Kitchen Range
Convert my belling DB90
You will have to change the orifice to accomodate lp gas.
Feb 03, 2009 | Belling DB90 Electric Kitchen Range
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Belling DB90 Electric Kitchen Range Logo
1,523 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
allphase tech
Level 1 Expert
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
