From HP: "The remote user pressed the Stop key, causing the session to be terminated." Meaning the problem is at the location of the fax you are sending TO. Call them, and ask them to confirm that their fax device is ready and able to receive.
You need to check parameters for LAN and e-mail settings (IP address, Subnet mask, gateway address, SMTP-server address, DNS-server address, etc). It is also important to enter "From address" in a correct form, i.e. name @domain.xxx otherways above error will be displayed.
Maybe depends on poor phone connection from this sender, caused by bad line or a transmitt problems. In faxsettings All fax, change "error correction" to off and "V34" faxspeed to slow, this will help.
The fax machine needs to be reset. Simply shut off the machine, wait one minute, and turn on machine & fax. If turning off the machine does not clear your machine then you have to unplug the machine & follow the same procedures. Worked for me.
