Driver download link: HP Officejet 7110 All-in-One Printer Driver
Connect the printer to the system and power on the printer. Start the system let it boot completely, put the CD that came with the Printer and install the drivers . From the same CD, run the setup to install the scanner software for the printer. Read cafefully the instruction on each installation wizard window that opens and follow the instructions.
However, if you are using windows 7 Operating system, just install the printer driver, go to start, All Program, Windows Scan and Fax. Lunch this and with it you can scan your document
SOURCE: can not print color on hp officejet 7110
it might be a hardware issue with the printer however we still can try the following stes to reset the printer.
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy
Thanks
SOURCE: My HP 7110 Officejet says
If you can remove the glass, you need to clean the lamp and mirrors in the scan assembly, this error happens after the lamp ages and dust gathers on the scan mirrors. It's very expensive if you can even find a new scan assembly.
SOURCE: I need help setting up my hp scanner Officejet 5610 all-in-one
Put the disc in, follow the instructions, and plug the device in when it asks
