Two line stable, compressed frames appear one above the other on the screen exactly dividing the screen in two. What board do you think the fault is on?
This sounds like a fault with the sustain boards. Can you provide me an image of the tv when the problem appears? Also I need a bit more info regarding the problem
1)Since these compressed frames appear in the middle of the tv, do they appear on top of the menus as well?
2)Do they lose color(monochrome) or do these lines retain the color?
3)Also do the lies stay all the while or appear/disappear a while after its turned on for a while?
Sai.
Where would one get the parts and how much??same monitor problems :/
Thanks for the response.
When I feed in a VGA signal from my laptop the panel displays two pictures the same, one above the other, as if the screen was split horizontally.
I did not check to see how the menu displayed and will check later today.
The color remained OK.
I only ran it for a few minutes but the picture remained during that time.
I will connect it up again today and take a digital picture of the screen and send it to you later.
Kind Regards,
John
Hi again Sai,
I set up the plasma display, this time with the back off, and noticed that a 47 micro farad electrolytic cap was venting on board ZSUS. (C16)
Is ZSUS the board that you suspected?
Anyway, I shut the whole thing off in case the failure of this capacitor took out something else.
I've ordered a replacement cap and hope that this does the trick. If not I will re-list and ask for you.
In the meantime I will accept your response.
Thanks and Regards,
John
Sai went straight to the problem area!
