I replaced the magnenta toner, now it still refuses to print and keeps asking "replace magnenta"
If you replaced it with a refilled cartridge it is possible that whoever refilled it failed to reset or replace the smart chip on the toner cartridge. If you refilled the toner yourself the new Magenta toner smart chip must be replaced. If it is a new cartridge turn off the printer, disconnect power, and reseat the toner cartridge. Make sure all fo the protective tape and plastic was removed and nothing is blocking the smart chip contacts from making contact with your printer's sensors. If that doesn't work I would see if you can exchange it for another and try again. If the problem persists it appears your printer may have a problem with it's toner remaining circuitry.
Get a new printer
