If u have drip pan on bottom of dishwasher it could possibly be it's sensing water on bottom of it u will need to slide unit out about half and look inside into dripping pan it's easy to get to it from left side if water is there try to clean out so tha star foam nice and dry make sure turn off power first then after all try to find a leak by running unit wale is still out and watch
Drain the dishwasher. There's a box in towards the front of the door. It's shaped like an oval. Carefully remove and clean that. Lift it up and down after and listen for clicking. Try running it again.
HERE IS A LEAK AND IT IS BUILDING UP IN THE BOTTOM DRIP TRAY!. It is filling up the drip tray and tripping the micro switch. Remove the lid(2 screws at rear),givng access to screws on top of right side panel,remove right side panel, you will have to remove plastic cover on bottom front first to give access to screws on side panel. This gives access to the hoses and such, where the leak is most likely coming from. I would buy some inch and a half to 2 inch hose clips first, as the clips on the machine are not really reusable.The machine will have to be put on its left side, you may have to remove the bottom drip tray also, this holds the micro switch and the polystyrene float. You may have to run the machine to see where the leak is coming from, It is time consuming, but very "doable", remember electricity and water do not mix,unplug and make sure everything is dry, particularly yourself!.
Look in the freezer floor to see if you have ice built up and over flowing into the floor. If so you have a clogged drain line which is located in the freezer behind the lower basket in the litttle gap at the bottom of the back wall. If you don't have that, the water line that runs to the water in the door is located at the front left side as well and you can get to that by pulling off the bottom piece of plastic that runs along the bottom of the whole machine.
Check if the dishwasher is level side to side and front to back. (you can generally tell if the edge of the tub has an even space between it and the cabinet at top and bottom, and the tub is not further in or out on top or bottom in relation to the edge of the cabinet. Also, make sure the door is not hitting the cabinet edge when you close the dishwasher door.
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Read the installation instructions and make SURE that you have removed all of the packing material from inside and around the door. If you had the bottom apron off to hook it up, some insulation may have poked up into where the bottom of the door seals. Inspect the area that the door seals really carefully - you often can't see the bottom of the bachine side, due to how the door bottom catches drips, but if there's something that is sticking up into the lip when the door closes, that can give you problems. If you can take the bottom skirt off and run the machine, you may be able to see where the problem is coming from. Good Luck! Jim
