There is a switch on the back to set time, alarm, or display time. Select the switch to time set first. Tap top of unit to toggle between settings blinking display is the one to be set. Change it bi tapping on the sides ( ) or(-) don't forget the 12 hour display or military 24hour. Switch back to clock display when hour and minute display are both blinking or the setting will not take effect
Set the clock to "Time Set" and use the + and - keys until you reach the correct hour you want (AM or PM) then tap the bots head to switch over to minutes. Works for the alarm and 12/24 clock settings too.
Usually setting time on any clock requires you to set the hour then the minutes. If there is a time button press and hold that, while holding down the hour button or scroll through the hours by pressing the hour button repeatedly until the correct hour shows. do the same with the minute button, this clock displays the time on the front so it should show you the number you are trying to set.make sure you check if you are setting am or pm.
I cant find a picture of the clocks time set buttons so am guessing..
