Miele Optima G2430SCi Stainless Steel Built-in Dishwasher Logo
Posted on Jan 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Intake light flashes and won't start. cleaned the water filter
David
Level 2:
  • Expert 177 Answers
  • Posted on Jan 25, 2010
 David
Expert
Level 2:
Answers
177
Questions
0
Helped
213038
Points
452
If this happens at the very start then the unit is not draining properly.
most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely.
Hope this helps.
ALL LIGHTS ON PANEL ARE FLASHING??
All the lights on my incognito started to flash. This was after the drain/intake light started to flash also. I called Miele and they helped me to reset the lights flashing. They said that when all lights are flashing that this indicates an overheat condition. They asked if my filters were clean and I thought they were. However, my wife had started to use liquid dish washing detergent and the liquid detergent had plugged up the filter screen at the bottom of the dishwasher. I cleaned it good with a scrub brushing and boiling water. This fixed the problem. Bottom line, don't use liquid dish washing detergent in a Miele, only powder.
Whirlpool/Honeywell hot water heater light flashes 5 then 7 times and won't light. Burner is clean and all contacts are good. Out of warranted.
Copy following link to troubleshoot by type of gas control valve, including directions for cleaning air intake screen, and or replacing gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
7 flashes: Gas control valve might be bad.
4 flashes: FV overheat, clean air intake.
Soot indicates clogged air intake slowed combustion venting possibly causing overheating and lockout. Clean air intake screen located on bottom of unit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dishwasher will not work
I had the same problem. on the same machine. when this light flashes it means that it cant easily intake or drain the water. just clear the filter located down the tube and clean all of its parts and the valve wich is down from a metal stipe next to the filter. after this press continiously the start button. this should do it!!!!
1helpful
My Miele dishwasher has water in the bottom of it and won't run
Check the impeller on the pump to make SURE it's turning freely. There could be a piece of debris wedged in there - like glass or a screw from a pot handle. If this is redundant, I apologize.
Red intake light comes on and dishwasher will not drain, model g 843 scvi
The manual is available here: http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Dishwashers&SubFolder=Previous%20models . Scroll down through the list to the G643 G843 Incognito. The maintenance items listed below are detailed on page 44 and beyond of the manual.
The Intake light is also the Drain error light. If the light is flashing, then turn off the dishwasher and clean the triple filter, the drain pump and the non return valve and make sure that there are no kinks in the drain hose.
Make sure the water is ccoming in at a pressure above 4.5 psi. Also make sure that the water valve is open and clean the water intake filter.
The final possibility is that the Waterproof system has tripped and you need a Miele technician to service the unit.
I hope this helps.
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
4helpful
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
13helpful
Drain intake indicator flashing. We have cleaned all but the intake filter. How do you clean or check to see if cleaning is necessary of the intake filter?
After cleaning the drain, looking at the intake (no filter on ours) and the light wouldn't go off, I just decided to take the ctrl-alt-delete approach and hit all the lower four buttons all at once, bingo, it cleared the light and machine started.
5helpful
2answers
Intake/drain light flashing
I have (had) the exact same problem with my Miele. Here is what (appears) to have fixed it:
1) Disconnect the inflow line at the water source. Its the connection that looks like a garden hose. Use a screw driver to remove the washer inside, the pull out the little filter with needle nose pliers. My was clogger with particles from the washer. Clean with soap and a tooth brush.
2) Disconnect the outflow line at the garbage disposal. My was moderately clogged with food (Note: my son overfilled the garbage disposal before running. It may have backed up).
This worked for now at least. Remeber, as irritating as red lights can be, it prevents the motors and pumps from burning out when you have clogged plumbing.
Kerry
1helpful
2answers
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Top Miele Dishwashers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
