Hotpoint Ultima WF860 Front Load Washer Logo
Posted on Jan 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it foamed up a lot and the F4 display is back again. Any ideas would be much appreciated. Thanks
Barry Coates
Level 3:
  • Hotpoint Master 3,463 Answers
  • Posted on Jan 25, 2010
Barry Coates
Hotpoint Master
Level 3:
Answers
3463
Questions
Helped
1405831
Points
12766
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 13, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1426
Points
Error F04, just removed the drain pipe from the pump (by removing the lower panel) and found a hair grip jamming the impeller
Anonymous
Level 1:
New Friend:
  • Posted on Aug 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1426
Points
My Hotpoint Ultima WMD 960 displays "F01" on the display panel unable to wash or spin, much appreciated on any input. Thanks
3 Related Answers
pjhislay1
paul
  • 825 Answers
  • Posted on Mar 22, 2011
SOURCE: hotpoint wmd 960 ultima,when press start button
if water starts but drum dont move.............
check the rear belt....if that is on then the motor needs new brushes............
easy fix ........... about £12 diy
cheers
Anonymous
  • Posted on Sep 16, 2011
SOURCE: cant find filter on my hotpoint Ultima
get the filter out of hotpoint wml520
Anonymous
  • 414 Answers
  • Posted on Oct 07, 2011
SOURCE: hotpoint ultima WMD 960 DISPLAYS E/7.==STOPS
F7 generally mean heater relay is stuckcheck the linkhttp://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
1helpful
F-04 on hotpoint ultima can you tell what this means please
"F04" on the display panel before the programme ends. Have you cleaned the filter out on the pump
Wmd 960 ultima switches on prog select ok but then does nothing - no whirrs or sounds of water going in - water available
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Hotpoint wmd 960 ultima,when press start button nothing happens apart from the clock starts count down to end of wash
cheers
1helpful
F-04 on my screen
F04 means pressure/water level switch jammed on empty
Check pump and filter located at rear of washer behind removable panel.
Thanks.
1helpful
Our washing machine will not pump out and we have lost the manual
it should be at the back of the machine were the pipe for dirty water comes out there is a panel you can take off at the bottom of the machine when it is off you should see the moter and the pump were the pump is you and take off the black sump asmbaly and the filter should be there. hope this helps.
Hotpoint ultima WD860 machine has stopped mid cycle displaying f-04 I have taken the panel off the back and cleared out the tube from the drum by removinng the clip but this has not worked. On thurning the...
f04 is a pressure switc problem.
take the lid off and check the clear plastic hose is attached to the bottom of the pressure switch, a round part with wiresand the other end to the sumps breather tube.if it is and there are no holes or splits in the tube it may need replacing.
2answers
Cant find filter on my hotpoint Ultima
Good luck. All modern washers that I know dont have the filter you need. If a clean out is needed you will have to clean out the pump.
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
