The line going from the shutoff valve on the wall to the Toilet is leaking - seems like the joint is leaking. What are my options before I call in the plumber ?
The product name may not be right, didnt find the right product.
****if its the tank supply line and one of the connections is leaking tighten the connection if stops done if continues to leak go to hardware ,home,or plumbing store for replacement $4-7 dollars turn shutoff valve off flush toilet to get most water out of way and disconnect line replace ****----if joint where valve is connected to main water feed if threaded try tightening connection if soldered will need to turn of water to bathroom or house and drain line and resolder connection same of pressure connection/threaded valve failure
