Hello there
If your dryer
won't heat up, it's possible that it is not being supplied with the
proper voltage. Here are three ways to make sure power is getting to
your dryer: First, make sure your dryer is plugged in. Next, check the
circuit breaker panel to make sure all the circuit breakers are in the
correct positions. Finally, check to make sure no fuses in your fuse
panel are blown. Any of these could explain why power is not getting to
your dryer.
Heating Element
It is possible that your dryer
isn't heating because its heating element is defective. Heating elements
are irrepairable. If yours has ceased to function properly, you will
have to replace it. Open your dryer's cabinet and locate the heating
element so that you can test it.
Thermal Fuse
Another possible cause for a dryer
not heating up could be attributed to a faulty thermal fuse. Once a
dryer's thermal fuse has blown, it is no longer of any use. If your
dryer's fuse is blown, you will have to replace it. Open up your dryer's
cabinet and locate its thermal fuse so that you can test it.
Thermostat
If any of your dryer's thermostats
have become defective, they could be the reason that your dryer is not
heating. Open up your dryer's cabinet and test each of your dryer's
thermostats. If any are faulty, replace them.
Timer motor
A defective timer motor could also
cause your dryer to not heat up. Test your dryer's timer motor. If it is
no longer functioning as it should, replace either the entire motor
assembly, or just its motor.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
properly.
if
no heat
tip....
heat.
check
out this electric
no heat
tip...
heatman101
