Question about Logitech X-240 Computer Speakers
Right channel only plays
Even after I changed it on the volume controls :(
  • Arkaze Feb 16, 2008
    thanks. I think it may be an internal problem then cuz the cords are connected properly.
    Scholar:
  • 99 Answers
I fyou're sure the cords are connected correctly, the problem may be a loose connection on the intereior of the speaker.
Posted on Feb 15, 2008
Anonymous
SOURCE:
My iPhone SE stopped making sound when ringing, it only vibrates. I have checked all settings/side button, all correct.All other alerts-text, etc.-still work with sound alerts. Anyone know how to fix?
One thing to check is the ringer volume - by default you can change the ringer volume using the volume controls on the side of the phone even when the phone is locked - this often means that it can get pressed in your pocket to zero volume, which is very annoying. Try pressing the volume up button from the home screen while not playing any music and see if it goes up. You can set the volume in the settings and even tell the buttons to only change music volume, which is what I do.
Jan 24, 2017 | Apple iPhone Cell Phones
How can I manipulate volume on a jvc tv 2012
If you can change the volume with the user friendly circuit controls on the set (if it has any) if not not the IC that controls the amplitude to the IF and AF amps has gone bad on it. This is my best guess because I don't even know what model or type the jvc is.
Gillight
Dec 07, 2013 | JVC Televison & Video
Volume
Right click the volume icon then click open volume mixer then check if anything is muted then unmute it
May 05, 2013 | Fujitsu Computers & Internet
WE HAVE A RCA HTS 5000 THAT WE CAN NOT FIGURE OUT HOW TO ADJUST SO THE VOLUME IS NOT ALWAYS SO LOUD BUT THAT CHANGES WHEN THE MOVIE OR SOUND CHANGES
Need more info. Are you using the volume control on the unit as your main control or the volume on the TV? I have a setup in which my sound is routed through a 5.1 Teac amp. The sound level on the amp os set and not changed. The volume control on the TV dictates the amount of sound. If the amp volume is set too high, then this will be amplified even more through the TV's sound input (the red and wite RCA cables).
If this is the case, turn down one of the folumes (the one that remains unchanged) and see what happens.
Jun 05, 2011 | RCA Audio Players & Recorders
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Heaphones volume through speakers
Unfortunately, the speakers are just passing through the sound and will not let you control the sound that it passes.
There are headphones, even inexpensive ones, that have volume control built in.
Please let me know if this answers your question. Thank you.
Sep 18, 2009 | Audio Players & Recorders
The volume control does nothing, you cannot turn it up or down even on zero you can hear music. There is a lot of static at all times, even when playing the CD
Looks like a lot electrolytic capacitors on the electronics volume control IC may be leaky...This require change of electronic components i.e. the faulty capacitors..
Aug 22, 2009 | Bose Wave Radio
Logitech X-240 Computer Speakers Logo
Top Logitech Audio Players & Recorders Experts
Ekse
Michial Gueffroy
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
