Question about Toshiba Computers & Internet
Have a Satellite P 305D-S9800; scoll bar will not pull down by mouse or touch pad; as soon as I let go it jumps back to the top please help
    Genius:
  • 1,189 Answers
The "Touchpad is very sensitive; if you look while scrolling, the "scroll-bar" will turn (Blue), click on the ("scroll-bar"), until it turn "Gray." Note: "You ca use the Pointer Device / Touchpad without using the Scroll-bar, basically anywhere on the screen; ("bottom scroll-pad" = left to right"), and ("right -side edge scroll-pad = up & down").
Posted on Feb 02, 2010
6ya staff
SOURCE:
TOUCH PAD FOR TOSHIBA SATELLITE M840 SERIES WON'T WORK, HOW TO FIX?PLEASE HELP :)
Press the function key with the image(mouse/no mouse).For M840 its [ F5 ].
Try [ F5 ] or [ FN ]+[ F5 ]. For other pcs it maybe [ F9 ] .
Sep 02, 2012 | lf New Toshiba Satellite M800 M800D M801...
My mouse on my satellite a660 scrolls up,down,left and right without a glitch but i can't get it to double click and enter to open up pages. on the opening windows 7 blue page where the little icon...
hello friend,
I THINK THE PROBLEM IS FROM THE MOUSE PAD, I THINK IS EITHER YOUR HAND IS WET OR SOME LITTLE WATER POURED ON IT, IF NOT, THEN IT IS DEVELOPING SOME FAULTS THAT I THINK MAY TAKE SOME TIME. PLEASE IF YOU CAN LOOK FOR AN EXTERNAL MOUSE TO USE FOR THE MINE TIME NOW AND AVOID TOUCHING THE MOUSE PAD FOR SOME TIME THEN I THINK IT WILL COME BACK TO NORMAL LATTER.
Jul 11, 2011 | Toshiba Satellite A660-BT2G22 Customizable...
The cursor of my toshiba satellite has gone out of control .
You can try reinstalling the driver. I'm not sure how old your computer is or how much use it's had, it could be that the touch pad is worn out and needs to be replaced. You could try using a plug in mouse or track ball. Track balls work better with a laptop and are more like using a touch pad.
Mar 25, 2010 | Toshiba Satellite A205-S5804 PC Notebook
The cursor of my toshiba satellite has gone out of control. It keeps on jumping uncontrollable when i attempt to use the touch pad. I can only use the mouse. Please help
try to check your touch pad without AC power i mean run your computer on battery if your touchpad working ok on battery so there is a problem with your adapter ampere ask any local repairing center to check your adapter ampere or change your adapter and do not purchase compatible adapter, compatible adapter can not resolve your touch pad problem go for original adapter from toshiba
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 23, 2010 | Toshiba Satellite A20 Satellite A25 Series...
Asus touch pad too sensitive
There should be settings in the touch pad software on your machine or in the task bar that you can directly access to change all manner of personal idiosyncrasies related to HID. (Human interface device) Try also going into the control panel and looking for input devices, mouse, touchpad and adjusting the settings from within there.
Mar 11, 2010 | ASUS Computers & Internet
Mouse becomes jumpey and wont grab scroll bars
do you have touchpad drivers installed....if you do...go to control panel - mouse - properties and change the settings
Nov 04, 2009 | Toshiba Satellite A105 Notebook
When typing the curser jumps to a different position
This is because you are touching the touch pad with your palms. when typing avoid contact with the mouse pad in your laptop. I hope this will help. Thanks.. Please rate this!!
Aug 16, 2009 | Acer Computers & Internet
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
Open Questions:
TOSHIBA PRINTER technical SuPpOrT PhOnE /@\18OO8O3*1O69/ NuMbEr U.S.viyadav... ONES TOSHIBA PRINTER USA phone number is ranked #2 out of 2 because 7,728 TOSHIBA PRINTER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31O69 is to reach the 8O3TOSHIBA PRINTER USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, TOSHIBA PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. TOSHIBA PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I:8OO:,:8O31O69 and ways to call or contact TOSHIBA PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling TOSHIBA PRINTER USA Calling TOSHIBA PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from TOSHIBA PRINTER USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with TOSHIBA PRINTER USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare TOSHIBA PRINTER USA's phone numbers against each other. Contacting TOSHIBA PRINTER USA in General While I:8OO:,:8O31O69 is TOSHIBA PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:8OO:,:8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach TOSHIBA PRINTER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact TOSHIBA PRINTER USA.
Nov 07, 2019 | Toshiba Computers & Internet
TOSHIBA PRINTER tEcH SuPpOrT PhOnE /@\18OO8O3*1O69/ NuMbEr U.S.viyadav... ONES TOSHIBA PRINTER USA phone number is ranked #2 out of 2 because 7,728 TOSHIBA PRINTER USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31O69 is to reach the 8O3TOSHIBA PRINTER USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, TOSHIBA PRINTER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. TOSHIBA PRINTER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I:8OO:,:8O31O69 and ways to call or contact TOSHIBA PRINTER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling TOSHIBA PRINTER USA Calling TOSHIBA PRINTER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from TOSHIBA PRINTER USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with TOSHIBA PRINTER USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare TOSHIBA PRINTER USA's phone numbers against each other. Contacting TOSHIBA PRINTER USA in General While I:8OO:,:8O31O69 is TOSHIBA PRINTER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:8OO:,:8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach TOSHIBA PRINTER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact TOSHIBA PRINTER USA.
Computers & Internet Logo
235 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
