Canon EOS Rebel XSi Digital Camera Logo
Posted on Jan 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i turn my flash off canon eos xsi - Canon EOS Rebel XSi Digital Camera
Anonymous
Level 3:
  • Master 668 Answers
  • Posted on Jan 24, 2010
Anonymous
Master
Level 3:
Answers
668
Questions
Helped
158152
Points
1894
In your camer there will be seven Full Auto modes : full auto, portrait,
landscape, close-up, sports, night portrait and FLASH OFF. Turn
the Mode Dial of the camera clockwise as far as it will go to
disable the flash. In Full Auto, the flash is also disabled in
landscape mode and sports mode.
Hope this helps.
4 Related Answers
Anonymous
  • 155 Answers
  • Posted on Apr 09, 2009
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Anonymous
  • 58 Answers
  • Posted on Sep 29, 2009
SOURCE: Have Canon EOS Rebel Xsi Digital. Burning smell and flash busy.
Are you trying to use the flash when you are having the problem? Were you taking a lot of pictures with flash when the problem started? Rapid pictures with flash can melt the flash and capacitors in the camera. Also, a single drop of water rolling around inside the camera in the right place can do things like that. You can try taking pictures in bright sunlight so the camera will not try to use the flash and see if it will work normally, If it does than something is probably fried in the flash system. Bad thing is that if you smelled smoke something is most likely already fried and will have to be repaired by canon. Canons quality has been going down hill for several years now and they have a lot of quality problems. If the camera has been used very little, has never been abused, dropped or wet and not far out of warranty, try using google to see if this is a common problem and call canon and try to get them to repair it for free. If all else fails threaten to replace it with a Nikon assume pay to have barely used camera fixed.
Anonymous
  • 7 Answers
  • Posted on Mar 30, 2010
SOURCE: I am missing my installation cd for my Canon EOS
go to this page, confirm it is taking you to the windows 7 version. previous versions of windows, like Vista, will probably not allow you to transfer photos without first loading this utility.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=16303#DownloadDetailAct
Anonymous
  • 47 Answers
  • Posted on Apr 19, 2010
SOURCE: canon eos rebel xsi not detected by mac (but it
the same thing happened to me, maby the camera has experianced a knock, try getting it seen to by a real person
External flash not firing in manual mode
In order to have your "External" flash work on your Rebel XSI, you need to go into the menu and turn on the external flash function. If you dont know how to enter into the menu mode, refer to your operating manual.
How do u turen auto flash off on CNnon EOS Rebel XSI 450D camera?
Is it normal to adjust the sharpness when downloading my pics. to picassa from my rebel xsi
Canon XSi will not turn on
I think flash pcb or main pcb gone dead so its require to change. Take it to canon service centre.
Canon EOS Rebel XSi pop up flash won't "pop down"
Do not Tape it down, If the flash is pooping up all the time take it to a good Camera repair shop to have the catch replaced. At the same Time you may consider getting a full service done.
Canon Xsi will not read external flash.
The XSi is not weather sealed like the 580ex II and is suseptable to liquid damage. Most cameras will take a few sprinkles and won't have a problem, but if the liquid got into the main body it might have issues. The top of the camera around the hotshoe is particularly sensitive.
I would doubt it could be self repaired. Take it to a liscensed repairer to have it looked at.
1helpful
When turning on the rebel xsi in the basic zone, I get a "this function is not selectable in the current shooting mode" message and I can't clear it.
Normally such message appear when trying to use the flash pusshin the flash rise button.
Flash will open manually only in non automatic shooting modes: P, Tv, Av,M and A-DEP
1helpful
My canon xsi on camera flash won't pop upeven after i press flash
I would suggest taking it to a technician to have it repaired. It does not seem like something you should try to fix yourself.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
