Samsung RS2630SH Side by Side Refrigerator Logo
Posted on Jan 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The filter light came on and tghe fidge started beeping. we replaced the filter but the fidge continues to beep. This a side by side Samsung --6 months old.
Anonymous
Level 2:
  • Expert 65 Answers
  • Posted on Jan 24, 2010
Anonymous
Expert
Level 2:
Answers
65
Questions
Helped
30477
Points
265
FILTER RESET
When the filter is replaced, reset the indicator by pressing the “POWER FREEZE” and
“ICE TYPE” button for 3 second at the same time.
If this doesn't work I would call 1800Samsung and have them send a technician to your home to help. The refrigerator does come with a one year parts and labor warranty. Hopefully this helps.
1helpful
Samsung HLS5687.Replaced lamp,turned on TV the light goes on turns off. The projector boards continues to beep then tv powers off. Color wheel does spin. Not sure what the beeping is.
Did you check the ballast for the lamp? It provides the high voltage/energy to excite the lamp (no filament) into operation. If it does not work properly neither will the bulb.
Great set - I have the 5685.
Beeping noise interior 2001escape
Same as the Ford Ranger. The Airbag Interlock for turning the Passenger side air bag off has a burned out light. You can dismantle this unit and replace the light with one from ford but it has to be soldered in place.
3helpful
I have a samsung side by side fridge freezer model SRS539HW, the alarm keeps beeping every minute to say the doors are open however they are closed. If I manually pust the door closer button it will...
Solved beeping problem.........Samsung SRS539HW . Have one of these and it is 6 years old. I had to replace the bottom hinge on the fridge side(right). Easy job but now constant beeping as if door is open, and light is intermittent. Found that there is considerable wear on the cable through top hinge of door and one of the wires from a magnetic reed switch in door had broken. I discovered this by shorting the two fine wires (white and pink/white) going to internals of fridge.No more beeping due to door opening and light now working correctly. Of course I no longer get a beep for a valid door open to long but cheaper than getting a refridgerator expert in.
1helpful
I have a 9-volt Strait-Line Stud Finder with 3 red LEDs and 1 green LED at the top end to mark the Stud Edge. I would appreciate it if I could receive step-by-step instructions on how to use the stud...
I suspect there are several models but I have one model. 1) Turn on the unit (if the green light is blinking replace the battery). 2) Calibrate the unit by holding it flat against the wall for 5 seconds until the red light goes off and the beep stops. Make sure you do not move the unit during the calibration or position the unit over a stud (try a spot 6-12" away from the corner of the wall - most studs are on 16" or 24" centers and the wood/metal stud is 1 1/2" thick). If the unit keeps beeping or the red light doesn't go off during the calibration, move the unit sideways 5-8" in case you are above a water pipe or other reason for "too deep a surface" for the unit.
3) Do not lift the unit off the wall or you will need to recalibrate it. Slide the unit across the wall. When the upper red light comes on and the beeping starts, that marks one edge of the object in the wall (stud). Continue until the red light goes off and the beeping stops. Mark the other edge of the stud by moving the stud finder in the opposite direction and marking when the red light comes on and the beeping starts. The center of the two marks is the center of the stud for securing anything to the wall.
If the beep persists over a 6" range, I'd check if you have any old cast-iron pipes or a door/window that was relocated in that wall. Repeating the test in a few places vertically along that spot of the wall will tell you there is a consistent large object in that location. Neither a filled in window or door will run the entire length of the wall but you could be finding the headers (the vertical framing of the opening would probably be ~4-6" wide (double or triple stud depening on the needs of the house design)).
I hope this helps.
(on another stud-finder that I borrow, you press the buttons on the right and left side to turn it on. Calibrate by holding it to the wall for a short while and then slide it across the wall. Note when the top red led lights and the beep starts. Repeat in reverse to find the other side of the stud.)
Sep 17, 2010 • Garden
1helpful
My computer cannot boot because of long beep
beep code usually means a basic function was unable to start. A basic function might be reading memory, displaying video, or being able to send information to a hard drive. The most common problems that cause beep codes are memory and heat-related failures caused by a build-up of dust in critical cooling areas. Use the beep code tables in this document to help find what hardware component is causing the problem. This might reduce the time required to find the hardware component that needs adjusted, reseated, or replaced. WARNING: HP recommends that these steps be performed only by someone with experience in working on computer hardware. Incorrectly handling sensitive internal components can further damage the computer and can introduce the risk of personal injury. Using the correct environment for working on computers (ESD precautions and tools), use the following steps to isolate and fix the problem:
  1. Turn on the computer.
  2. Listen to the beep code and write it down. Write down the number of beeps before each pause, if the beeps are long, short, high in tone, or low in tone. You can use the other sections in this document to look up the beep code description. The beep code and its description can be used for further Internet research if needed.
  3. Note which fans are spinning, not spinning, or making strange noises. It might be possible to prevent the beep code by setting the fan speed to a higher setting in the BIOS setup utility or by cleaning the cooling fins and vents.
  5. Check the case fan and power cable.
    1. Turn off the computer by holding the power button for five seconds.
    2. Disconnect the power cord and then disconnect all external cords from the computer.
    3. Remove the side panel to open the computer.
    4. If the case fan was not spinning, make sure the case fan power cable is connected to the correct pins on the motherboard. Replace the fan if it was making excessive noise or was not spinning. If you had to plug in or replace the fan, replace the side panel, plug in the power cord and turn on the computer. If the beeps continue, continue to the next step.
  6. Disconnect the power cord and remove the side panel and perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
    1. Clean cooling components that have become clogged with dust. If beeping continues, continue to the next step.
    2. Remove a memory module. If the computer stops beeping, the memory module might be bad, is the wrong type of memory for the motherboard, or was not fully seated or connected. Reinsert the memory into the socket to see if a connection was the problem; otherwise replace the module. Remove each memory module, replacing the one that was previously removed. If beeping continues after checking all the memory modules, continue to the next step.
    3. If the computer has a graphics adapter, remove it. If the beep code changes or continues with the same beep pattern after removing the graphics adapter, the adapter might still be good. Reseat the graphics adapter into its socket and continue to the next step. If the beep code goes away, the graphics adapter might be bad. Try reseating the graphics adapter, making sure it is fully locked into the connector on the motherboard. If problems continue, replace the adapter.
    4. Remove a PCI card. If the beep code goes away, the card might be bad. Try reseating the card into its connector on the motherboard. If problems continue, replace the card. Remove each PCI card, replacing the one that was previously removed. After checking all cards, if beeping continues, continue to the next step.
    5. Disconnect hard drives and CD or DVD drive cables (IDE and ATA) from the motherboard socket. If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems continue, the drive itself might be bad and might need replacing. Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. After checking all connections, if beeping continues, continue to the next step.
    6. At this point, the problem is probably the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case. Make sure jumpers are set correctly. Otherwise, have the computer serviced by HP or by a qualified service center.
2answers
3 beeps
Please Try this :-
:- Perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and ()listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
Remove a PCI card.
1helpful
Beeping
the beeping usually is there to tell you something.
It is possible there is not hot water being supplied when you have hot or warm selected
Maybe the water is filling to slow
maybe the filter i clogged
maybe the barrel is out of alignment ( cased but imbalance from previous wash )
is it a top or front loader.
what lights flash when the beeping occurs?
Beeps 6 times, lights blink
The prinwheel sensor is likely the issue.  Move the carrier to the right, on the left side of th carrier toward the rear of the machine there should be a small black "flag" sticking out of the carrier.  this should move freely in and out if it is not there or does not move the machine cannot detect the printwheel the sensor will need to be replaced.
  You ca also check for debri down in the area where the printwheel sits.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
