Aastra Telecom Aastra MDC Centrex Telephone Logo
Posted on Jan 24, 2010
How do I program the directory on the aastra m5316 phone?
Fix display lines justification on Aastra M5316? It’s so left justified that first bit of info is cut off.
To adjust the display lines justification on an Aastra M5316 phone, you can follow these steps:
  1. Press the "Menu" key on the phone.
  2. Use the arrow keys to scroll to the "Contrast" option and press the "Select" key.
  3. Use the arrow keys to adjust the contrast of the display until the lines are fully visible.
  4. Press the "Next" key to scroll to the "Line Justify" option and press the "Select" key.
  5. Use the arrow keys to adjust the line justification until the lines are properly centered on the display.
  6. Press the "Save" key to save your changes and exit the menu.
If you continue to have issues with the display lines justification on your Aastra M5316 phone, you may want to try resetting the phone to its default settings. To do this, press the "Options" key on the phone, then scroll to "Reset Phone" and press the "Select" key. Confirm that you want to reset the phone and it should revert to its default settings, including the default display line justification.
If the issue persists after resetting the phone, it may be a hardware issue and you may need to contact Aastra customer support or a qualified technician for further assistance.
1helpful
Trying to change the number of rings before my phone goes to Voice Mail on the Meridian (Nortel) M5316. Only two rings currently so I miss a lot of calls. Thanks!
Depending what system your provider is using it can either be done by you at home or they will have to set it. If you call your provider they will help you or they will fix it. Each ring is set at 6 second intervals so if you have 3rings that is 18 seconds. If you was 6 rings then ask for 36 seconds etc. hope this helps
Does the phone run on batteries
The phone can get some power from the loop like a basic telephone. That should suffice to make phone calls.
But many of the advance features and display options cannot work on loop power alone. You have to get a special plug that plugs into the wall AND the phone jack. Then plug the phone into that.
I am not aware of any battery in the phone.
I have a Meridian M5316 and the there is an existing voicemail on the phone how do I change the voicemail without knowing the current password?
Your provider will have to reset it for you. Phone them and ask for a reset. They may charge you a dollar or so. But that is the only way
I've lost my user manual and I need to reset the date and time.
I lost a user manual, then found this site called find my manual. They emailed it to me in about 2 hours and it only cost about £3, which i thought was very reasonable.
http://findmymanual.com/
Hope this helps.
Jane
22helpful
2answers
How do I erase the "I Select" features from the Vista 390 screen?
None of the phone numbers I have to delete this annoying problem work anymore. Is there another solution out there?
2helpful
Need manual
If you haven't received an answer to your request, You can find the manual at the following url:
http://www.florenceinc.com/en/documentation.php
If it doesn't take you right to the correct page, enter M5316 in the search window and it should find it for you. I tried to upload the document but there was no way to do it. Hope this helps.
Do I need a network?
If that model phone has a rj14 jack ( standard phone jack) and when you plug it into a known good wall jack and you can draw dial tone then it will work. If not it requires a KSU to interface with the lines and that's a lot more equipment than you need for 1 or 2 lines. Thank you. Jer
Top Aastra Telecom Lands Phones Experts
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
