Measuring Tools & Sensors Logo
Posted on Jan 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a Dewalt D55168 air compressor and I lost its owner's manual. Where can I get or download it, please?
Dale Gildner
Level 2:
Sergeant:
  • Expert 186 Answers
  • Posted on Jan 24, 2010
Dale Gildner
Expert
Level 2:
Sergeant:
Answers
186
Questions
8
Helped
57098
Points
504
My Dewalt 15 gal D55168 air compressor will not continuously build air after air supply has been depleted. Please provide help or a service center close by. I live in NW Oklahoma. Thank you.
you may be using more air that unit can supply. This is a very common error. it is only 5 cfm which is small.
Call Whitton Supply Co. or visit our local Oklahoma City showroom (405) 236-5561.
1helpful
Dewalt D55168 225 PSI Air compressor: What are the preset pressure limits for this model? Is it actually 225 - 180?
https://www.manualslib.com/manual/494085/Dewalt-D55168.html
Specifncations
MODEL D55168
WEIGHT 88 Ibs. (39.92 kg)
HEIGHT 41.75" (1060.5mm)
WIDTH 19.0" (4826 mm)
LENGTH 21.25 (539.8 ram)
AIRTANK CAPACITY (GALLONS) 15 Gallon (56.8 fiters)
APPROX CUT-_N PRESSURE 160 PSI (1103.2 kPa)
APPROX. CUT-OUT PRESSURE 200 PSI (1379.0 kPa)
SCFM @ 90 PSI (620.5 kPa_ 5._
cant get fixya comment to work so will edit here...
The 200/160 are the typical DS55168 settings from factory and meet the 90 psi @ 5.4 cfm rating.
Pressures can be adjusted to a MAXIMUM 225/185 with a resulting lower cfm rate.
I'm not familiar with "type 9". Likely nothing special just different setting from factory?
I HAVE A BRAND NEW DEWALT D55168...I'VE HAD IT ABOUT 3 MO.S... I WAS USING IT INSIDE ABOUT 2 MO.S AGO AND IT SIMPLY STOPPED... I HAVEN'T HAD TIME TO DEAL WITH IT, AND I DIDN'T FILL OUT WARRANTY...
If you bought it at HD return it for a new one. If not you will need to use a meter and check power from receptacle to on/off switch to pressure switch., Check motor winding. If all else fails call Dewalt and they will help you.dfffd6xqamff+a17gofmrmxewaaaaaelftksuqmccaa==
2answers
Dewalt D55168 air compressor runs until 95 psi and never stops. Pressure never goes above 95 psi. It use to stop around 140 psi.
Check for leaks all over the machine. Possibly the O ring on the drain valve is damaged. If the machine is oil-less, the big rubber O ring on the piston could be worn away.
When the machine is turned off can you hear air leaking from anywhere?
I have a dewalt D55168 air compresser. motor stays running ,air pressure won't go over 35 psi.. thanks , frank n2141s
Here is a parts diagram for the air compressor:
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D55168/D55168_PL.pdf
There are a couple of things to look for on the air compressor.
You will need to see if the piston ring is damaged or if you have a broken reed on the valve plate.
These are typically the two most common problems with this model.
1helpful
D55168 lost compression while running
The dewalt model d55168 is a high-end oil-free compressor. Oil free compressors could have a short life span due to dusty or dirty conditions at the job site. The cylinder of your compressor is open from the bottom and will **** in debris scratching the cylinder/ silicone-vinyl piston ring reducing pressure. However the reduction in pressure will be over time till the point that the compressor will not reach cut-out pressure and just keep running. If you lost pressure suddenly to "0" then you probably lost the drive belt. A replacement can be found at a local dewalt service center or ordered thru www.toolpartsdirect.com. When you take down the compressor, be sure to examine the cylinder /piston for wear. These are the two most common problems. Good Luck on your repair and email if you have other questions.
Top Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
