HTC Touch Dual Slider Smartphone Logo
Posted on Jan 24, 2010
My htc wont open and when i connect charger, led light goes red what happen?
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 04, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
2545
Points
9
Maybe your battery is dead and will not charge. Normally when you connect the charger the led must become orange after a few seconds and green when the battery is fully charged. If it stays red the battery is not charging.
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Htc wildfire not fully charging always show the led red
When want to charge htc wildfire it is better you turn the phone of before charging. Plug in the charger and charge for about 20mins to 30mins then remove the charger pin-mouth for like 10secs and plug it back in. soon the red light will turn green in less than an hour..
2answers
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
2helpful
2answers
My HTC mobile not going to on after pressing power button and on connection of charger it is showing red LED. Same there here. I woke up this morning and my phones just dead. Even if i connect the charger...
Remove the battery then connect the charger without the battery. Then hold down the power button for a few seconds. The red light may come up for a quick second during this process.
Don't remove the charger. After the red light goes off then insert the battery and check if the light turns amber or orange.
Leave it in orange or amber light state for about 2 minutes. After that, try to turn it on. If it turns on then it is resolved. If not then there is a hardware problem with your phone and it needs to be checked at any HTC Service Center.
My bold wont turn on. when charging, red light goes on and off
did you try the car charger,wall charger might be faulty,if that does'nt pan out,might need new battery
MY HTC P3400i IS DEAD. Just doesn't turn on.
There may be a physical issue with your logic board. You can get the part at HTC p3400i Repair and there is a guide that shows you how to put in the part at HTC Repair Guide.
2helpful
H700 wont do anything
I think the charger is the problem. I ordered one of these and then it wasn't charging the day I got it....it's supposed to go from red, to orange to green as it charges, but the red LED just goes off after a while, before the headset is fully charged. I solved this by charging it through a USB-to-miniUSB cable on my laptop USB port. This worked beautifully....unfortunately I think the H700 chargers are faulty.
5helpful
2answers
Htc not turn on, red light on
Remove the battery from the mobile, press the power button, for 30 seconds.
Re attach the charger , switch on the phone. If it turns on switch it off again and reinsert the battery and check.
If none of the above steps work, you would have to take it in for repairs as there could be a problem with the power supply inside the phone , that would require special tools to open
Thanks
proton
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
