Watch your impedance, when you add speakers the impedance will change. example 8 ohm speaker placed in parallel with another 8 ohm speaker the impedance is 4 ohms, placed in series the it is 16 ohm Me I would place in parallel this mixer should handle 3 ohms
You need to use an amplified sub. The Yamaha receiver is only sending "Pre-Amp Signal" not amplified audio like the rest of your speakers. If your sub has a crossover built in, connect it's speaker level (wires) to the "B" side of the receiver which will send audio to your sub and it will cross it over internally. Not the best sounding, but it works. Amplified subs range in price from 200 and up. Hope this helps
You may have a microphone plugged in - remove it and test. If that is the problem, then you need to reduce your mic level. Also, I have relocated my mic farther from my speakers - with great success.
check the battery, if dead replace new. check the switch might be a cold solder or loose wire and finally check the condenser mic by placing a multitester to the two connectors of the mic with one wire from the mic desoldered. if there's a continuity, then its good. if there's no continuity the mic condenser is busted. go to radioshack and find replacement mic condenser.
We had this problem too. Can you perform any functions with the duet mic? We couldn't, just had the light flashing. Turns out the light is supposed to flash (never is solid). Check the connections to the sub mic pack in the back of the main mic. Ours was loose. Once that was plugged in properly, we turned everything off and started again. All was fine.
i know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
