Apple iPod nano Logo
Posted on Jan 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i plug my ipod into the computer and open itunes the icon of an ipod will not appear in itunes and i cannot add new music
Anonymous
Level 2:
  • Expert 201 Answers
  • Posted on Jan 26, 2010
Anonymous
Expert
Level 2:
Answers
201
Questions
0
Helped
51249
Points
446
1) Try other USB ports on your computer, especially those on the back panel.
2) See if the USB cable is damaged.
3) Try the iPod on another computer with iTunes installed, to determine whether the problem is with the iPod or the computer.
2helpful
How do i upload songs
How to Upload Songs to an iPod: (You can also find the instructions here.)
1)Download the latest version of iTunes. It is free and you can obtain it from the Apple website. It could have come with your iPod on an installation CD. Makes sure your computer meets the requirements. You can find older versions on the web, but they have limitations.
2)Scan your computer for songs to add to the library.
3)Connect your iPod to your computer with the USB cable that came with your iPod. The iPod screen should say "Do not disconnect".
4)Open iTunes. Your iPod should appear under Devices in the bar to the left.
5)Follow the instructions for naming your iPod and changing the initial settings if the iPod has not been plugged into a computer before.
6)Buy music from the iTunes music store or import songs off a CD using iTunes.
7)Decide whether you want to sync your iPod with your iTunes library or manually put songs on your iPod.
(Syncing your iPod will automatically add all of the songs in your library to your iPod. It will also delete any songs from your iPod that are not in your library. Click on your iPod icon and select Sync in the lower right corner.)
8)If you do not want all the songs in your library on your iPod, make a playlist of all the songs you do want, or decide which playlists you want to include on your iPod.
9)Click on your iPod icon.
10)On the top bar, click on the button which says "Music".
11)Make sure the box that says "Sync Music" is checked, then check the box for whether you want your iPod to sync with the entire library or selected playlists. If you click selected playlists, select the playlists you want in the playlists category. For newer iPods you can check which artists are included on your iPod to automatically import all the songs from each selected artist onto your iPod.
12)Properly disconnect your iPod using the eject button (see Warnings).
13)Listen to your new songs!
TIPS:
Set up the iPod on the computer you plan to use it on. An iPod set up with a Macintosh will need to have all the songs deleted in order to use it on a Windows operating system. This only needs to be done once if you switch computers, but just to make less hassle, try to use the iPod on only one computer.
WARNINGS:
Make sure you disconnect the iPod properly to avoid problems or loss of files on your iPod. Click the eject button next to the iPod icon in iTunes, or in the lower, right-hand corner. If you quit iTunes, drag the iPod icon on your desktop to the trash to eject (Mac). Right click on the iPod icon on your desktop on a Windows PC.
Things You'll Need:
- USB connector cable
- iTunes
- iPod
- Computer
- Music files or CD's
Hope this information helps!
tip
How to get music onto an iPod without removing the previous music
<p>Sometimes when adding music to your iPod through iTunes on a new computer or another computer, the program will attempt to synchronize the device with the music available on the computer. All songs on the iPod, but not in your iTunes library will be removed. This can cause problems for people who just want to add songs to your iPod without losing their old music. Fortunately, Apple allows users to manually add music to the device, avoiding the problems of synchronization. <br /> <p><br /> <p>1. Open iTunes. <br /> <p><br /> <p>2. Connect your iPod to your computer using the USB cable. A prompt will appear warning that the device will synchronize the music to remove. Click "Cancel" if this happens. <br /> <p><br /> <p>3. Click the iPod listed under "Devices" in "Library". This opens the "Summary" page for the device. <br /> <p><br /> <p>4. Check the "manually manage music and videos" box to the bottom of the page. <br /> <p><br /> <p>5. Click on "Library" on the left sidebar of iTunes. Mark all the songs you want to add the device. Drag and drop it on the iPod listed under "Devices." <br />
on Jul 21, 2011 • Computers & Internet
tip
How to use one then one iPod with one computer
Method One
If you share your computer with other people, you can maintain separate user accounts for each person who uses the computer. This is useful especially if each user has different tastes in music; users can maintain separate, personalized iTunes music libraries and can customize their iPods accordingly.
Mac OS X users:
Learn how to set up additional user accounts.
Windows users:
Look in your computer's Help documentation to learn how to set up additional user accounts. To locate this information:
Click the Start Menu, and then click Help or Help and Support.
Enter "new user" in the Search field.
Press Return.
If you create multiple user accounts on one computer but want the same music to be available in iTunes for all users, see iTunes: How to share music between different accounts on a single computer.
Method Two
You may use multiple iPods on a computer without the need to create multiple user accounts. To do this, you can set iTunes to update each iPod with only certain playlists. This method allows you to put all your music on, say, your iPod and keep your iPod shuffle updated with only your workout music. Here's how to do this with iTunes 9:
Create new iTunes playlists that contain all the music that you want to sync to each iPod.
Learn how to Sync your iPod (read the iPod Tutorial Steps section below the video).
Note: iTunes for Windows does not support syncing multiple iPod devices at the same time.
Method Three
Create a separate iTunes library for each iPod. Note: It is important that you make a new iTunes Library file. Do not just make a copy of your existing iTunes Library file. If iTunes is open, quit it.
Mac users: Hold down the Option key while you open iTunes.
Windows users: Hold down the Shift key while you open iTunes.
In the dialog that appears, click Create Library.
Name and save the alternate library file. iTunes opens with your brand new library file.
Open iTunes Preferences. Choose iTunes > Preferences (Mac) or Edit > Preferences (Windows).
Click the Advanced tab.
Deselect the "Copy files to iTunes Media folder when adding to library" checkbox if it is already selected and click OK. This will prevent iTunes from creating duplicates of your existing media files in the new library folder.
Add the specific media files you want on your iPod to iTunes either by dragging them into iTunes or choosing File > Add to Library (Mac) or File > Add File to Library or Add Folder to Library (Windows).
Once you have the iTunes Library just how you want it, connect and sync your iPod.
Once the sync is complete, quit iTunes.
Click Choose library.
Choose your original iTunes Library and click Choose (Mac Users) or Open (Windows Users). You can now switch back and forth between the different libraries for different iPods.
on Apr 14, 2010 • Computers & Internet
How to add new mp3 songs
Install iTunes
Before you connect your iPod shuffle to your Mac or PC computer or use it, you must install the latest iTunes software.
2. Connect and Set Up your iPod shuffle Charge your battery by connecting it to an Apple iPod Power Adapter or connect your iPod to a high-power USB port —one that's located directly on your computer—to ensure that your computer charges your iPod battery. (If your computer doesn't seem to recognize your connected iPod , wait about 30 minutes to allow the iPod battery to charge before going further.)
3. Fill your iPod shuffle and iTunes with Music Once you finish the set up, iTunes will open. It will then either:
  • Automatically start filling your iPod with music from your iTunes library (if you set iTunes to automatically update your iPod)
OR
  • Allow you to pick and choose what music, audiobooks, and podcasts to add, if you opted to manually manage music on your iPod.
To manually add content, simply drag any file from your iTunes library or playlist to your iPod icon in the iTunes Source list. If you're using iTunes for the very first time, you'll need to add some music to iTunes first, such as songs from your own CDs or music already on your hard drive.
4. Disconnect your iPod shuffle Once you've got your music, audiobooks, and other files on your iPod, you're ready to enjoy it.
  • If you see an “OK to Disconnect” message on your iPod, simply disconnect it from your computer.
  • If you see a “Do Not Disconnect” message, click the eject icon that appears next to your iPod icon in the iTunes Source list and then disconnect your iPod from your computer when you see the “OK to Disconnect” message.
  • Disconnecting my iPod shuffle
5. Play your iPod shuffle Now you’re ready to enjoy your iPod.
6helpful
4answers
My Ipod nano contains all my music. Unable to transfer to laptop
Unfortunately iTunes doesn't let you transfer anything other than your iTunes store purchases from your iPod.
Totransfer all your iPod content, all your music, playlists, videos,podcasts and photos to your new iTunes library you will need todownload software like TouchCopy.
Here is how to use TouchCopy
  1. Download and Install TouchCopy. Downloads are free and are available for both PC and Mac.
  2. Start up TouchCopy by double-clicking the TouchCopy icon on your desktop
  3. Connect your iPod or iPhone to your computer. TouchCopymay start iTunes - don't worry, TouchCopy has fixed it so that iTuneswill not sync music or video with your iPod while TouchCopy is running.These changes are restored when you quit TouchCopy.
  4. Now select which songs you want to copy into iTunes, if you want toselect all your music, select "Music" from the list on the left andclick on "Copy to iTunes" button in the TouchCopy control bar. In a similar way, you can also use TouchCopy to copy your playlists, videos, podcasts, photos, contacts, calendars and notes.
  5. Whenyou are satisfied that all your iPod content is safely in iTunes, useiTunes to re-sync your iPod which will enable you to add new content toit.
2answers
I need the instruction on how to set up my
here's the website: http://support.apple.com/manuals/#ipod
you can download the user manual from there.
3answers
How do i transfer muisc saved on my computer to my ipod nano
open up itunes and the music library tab then drag and drop your saved music into itunes the music will take a little while to load but after it does you will be able to sync it to the ipod
3helpful
4answers
I can't put song from my computer to my ipod and when i connect it to my computer the icon of songs doesn't appear only device and accessories
  1. Double-click on the "iTunes" icon to open the program and then transfer all of your music filesinto iTunes. To add music from CDs, simply load a CD into yourcomputer's drive, wait for iTunes to see the playlist and then click"Import." To add music from another program, go to the "File" menu andselect "Add to Library." You will then be able to click on any musicfiles you would like to transfer.
  2. Plug your iPod into a USB port on your computer and wait for iTunes toautomatically recognize the device. You will be asked to name andregister your iPod, after which you can click "Finish" and begin toload music.
  3. Click on "Library," found in the left hand column to reveal all of themusic you have transfered to iTunes. To load songs onto your iPod,highlight one or more songs and then drag them to your iPod. Your iPodwill be found in the same column where you found the library, under thename you chose earlier. As soon as you drop the files into your iPod,they will quickly copy.
  4. Eject your iPod once you have loaded all of the music you'd like byclicking on the arrow next to your iPod's name. When the namedisappears, you can remove the USB cable and begin enjoying your portable music.
Here is where you can get ITUNES: http://www.apple.com/downloads/
2answers
Transfer
You can go here and download this free software which will allow you to take music off of your ipod and put it on your computer and transfer it to itunes easily: http://www.copytoy.com/
I jus gotta new ipod nano 2gb, i plugged it into the comp and it shows apple sign then "do not disconnect". a auto play window opened and it appears in "my computer". i click on it and it shows three...
First, you should use itunes for you iPod. I know that there are other programs that can let you load music on it, but you should use iTune, Really.
1. You should first download iTunes. It is free.
2. Next. Load your music into iTunes. Do all of this BEFORE you plug your iPod into the computer.
3. Connect your iPod to the computer. Use a fast USB port. These are usually located on the back of the computer.
4. Your iPod should appear in the iTune pane on the left side. You should be able to see a set of 'tabs' that you can click. The first one is about your iPod.
5. At this point, you can click on the music tab to tell the computer to load what to load into the iPod. Click 'sync' to load your music.
6. When the syncing is complete, you will see that notice above in iTunes. Click the arrow next to the iPod picture in the iTunes pane to discharge the iPod. The iPod picture will disappear. Make sure that you also safely release the iPod in the task bar at the bottom of the computer. You will need to click on a green icon that looks like a plug and select 'safely remove storage device'. Wait until the computer tells you it is safe to disconnect it. Then disconnect.
Hope that helps.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
