Used it closed the door and happened tp look up a few moments later.No display ,no lights nothing ------ no electricity.I checked the wall outlet and it was still good ,checked the two small fuses on the board directly behind the keypad.They checked out with a volt tester,no breaks in the path anyway.Is there another fuse location?could it be something else?
SOURCE: Samsung Microwave model # SMH7178STD just stopped working.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find Samsung-specific parts here: http://www.samsungparts.com/search/search.asp
SOURCE: Just quit. No power, no display....nothing
there are several possible causes, check voltage at outlet
check the 20 amp bus fuse on the main board ohm out the cavity thermostat, replace the bad part
SOURCE: Samsung C100 microwave is now dead
hi my name zoya some problem micro plz contact me soon 9885958205
SOURCE: Checked fuse it's ok only
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
SOURCE: Our 2006 Samsung Microwave has
Press
the "Off/Clear' button to cancel anything on the display, and reset the
microwave. This is a soft reset and will simply get you out of any
program you have started. Press it when the cooking complete reminder
appears on the display.
Perform
a hard reset. Pull the plug out of the wall power supply, and wait a
moment. Plug the GE microwave back into the wall power supply to reset
any anomalies with the microwave's memory. You will need to reset the
time of day if you perform a hard reset.
Reset
the time of day. Press the "Clock" button, and turn the dial to set the
hours. Press the dial to enter. Follow the same procedure for the
minutes and a.m. or p.m. Press the "Start" button to start the clock.
I would think the small fuses You mentioned may be just for protecting the board. Is it possible there is another fuse and fuse holder inside the unit. I would remove the outer cover and follow the power cord to a main fuse holder. If it went out when you opened and closed the door, you may have a bad door switch that caused the fuse to blow. Check all of the door switches while you have it open.
Also, had you cooked in this for a long time before it went out? It is possible the main fuse got hot due to bad onnections at the fuse holder and melted the fuse. May need a new fuse and fuse holder.
