When I switch on my Fuji S602 zoom it displays a 'card not iniialized' error message. I tried different cards and attempted to reformat the cards in the camera but with no success. Any ideas?
Id did this, too.
if you rename the camera folders , toast.
says so in book page , 4 bullets up, bottom right of page.
I renamed my cam folder to S602 , that killed it.
you can not delete folders or files from PC ever.
only from the camera.
the names are all sacred
now i cant format using the camera either.
nasty feature.
will post with solution if any.
formating with PC is crazy there are huge numbers of format profiles, all are no good.
Make sure your card is compatible for your camera, and or it is not defective. I know that with some camera models the card must meet specific specs. Consult your camera dealer or call Fuji photo support to verify if your card is compatible.
If you have the adabtor for your card to be used directly on your computer, you can see if formating your card with the computer will help. This is not the proper fix, but it may work for you.
Jerry G.
Hi Jerry
Thanks for the suggestion. I managed to use my PC to re-format a card that had worked in the camera before this problem appeared but no joy. Still getting the ' card not initialized ' error message when I switch on and ' !card error ' if I use the format option inside the camera.
