Passing on the solution. Some other blogger helped me, so I hope this will help you. Mine is a Kenmore Gas range, but the hinges might be similar. They are fixed on the door, not on the range. Get a couple sturdy nails or similar items and keep them in your hand. Use your foot to push the hinge all the way down, as if the door were fully open. You should see a hole in the hinge, in which to insert the nail to hold the hinge open. Repeat on the other hinge. Carefully lift the door in place and set the hinges so they hook onto the latches properly. You should be able to open the door a bit to take the tension off the nails. remove the nails, and that should be it. Even if your hinges aren't the same as mine, the principle seems to apply. My problem (maybe yours) was that I couldn't open the hinges and keep them open when trying to replace the door. They just would snap closed. Very frustrating.
I have a kenmore electirc oven that in the off mode the broiler element is still on like it is cleaning. any idea on what to do
