Question about Sanyo EM-V5405SW 1200 Watts Microwave Oven
Seems to be working but does not heat up. - Sanyo EM-V5405SW 1200 Watts Microwave Oven
  • 1 more comment
  • Anonymous Jan 24, 2010
    Door microswitch's are fine.
    Is the magnetron the only possible cause?
    Is the magnatron the only possible cause? How about the diode or the capacitor?
  • 3,037 Answers
This means the Magnetron (this is the part that heats the food) has broken especially if everything else works as usual. Generally it is not work replacing the part as it is almost as cheap to just buy a new microwave since it is the most crucial part of the microwave. You can find the replacement part at repairclinic.com, just enter the model number of your microwave to find the right part. My recommendation is to just replace the microwave as it will be much easier and the new one will be less likely to break sooner.
Let me know how this works out for you.
Benjamin
Posted on Jan 24, 2010
Testimonial: "Thanks for your input. It has been very helpful."
  • Benjamin Patri
    Benjamin Patri Jan 25, 2010
    Generally it is the magnetron and usually I don't have people try to mess around too much with checking other parts because of possible dangers and many don't have the knowledge to fix the problem. As long as all other settings work and their is a good connection between the magnetron and the board, then it should be the magnetron. If you see a buldging capacitor, then by all means try replacing it as they are cheap but 99% of the time, the magnetron itself is bad.
  • 1,531 Answers
If the unit is running and the turntable is going then the only thing that can be wrong is a bad magnetron.and should be replaced
  • 443 Answers
The magnatron has either failed or has burnt the circuit protection fuse inside. Depending on how much the microwave cost you to purchase, and with the cost of service shops diagnosis fees these days it may be time to replace the microwave rather than invest in service.
If it happens to be under warranty take advantage of the manufactures warranty!
Good luck !
    Brigadier General:
  • 3,513 Answers
This is a problem which is seen when the top door micro-switch does not work properly. Please check if the spring has lost its springiness, causing the switch to remain open (ie, not closed and conducting juice). Would request to have it removed. You can get to the switch by opening control panel to get to it, bent the spring, put it back .Oven would start heating again.
Let us know if you were looking for something else.
Thank You
Posted on Jan 23, 2010
6ya staff
SOURCE:
Microwave seems itis working fine but not heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Nov 26, 2010 | Maytag MMV4205 Microwave Oven
Does not heat up properly. Seems it lost it's
Assuming the turntable works maybe your magnetron isn't working properly. Cheaper to buy new microwave then to fix it.
Apr 30, 2010 | Kenmore Microwave Ovens
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Dec 11, 2009 | Kenmore 62622 Microwave Oven
Things are not heating up in the microwave
My GE Spacemaker Microwave oven does not heat up. Every other thing works. Model JVM1640
Jul 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave seems to work but doesn't heat up
HI, when the Magnetron becomes unstable, the microwave will not heat anything. simply replace the Magnetron. This device creates the heating action and it is damaged and not functional at this time.
Jun 01, 2009 | Sharp R-1870 Convection/Microwave Oven
Jenn air microwave....
Probally the belt is broken on fan up at the top.
Mar 13, 2009 | Jenn-Air M439 Microwave Oven
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Everything works but the heat! Any suggestions?
door micro switch open/need to replace / if that open the magnetron will not power no heat will produce.
Jan 02, 2008 | Whirlpool MH1150XM Convection/Microwave...
Sanyo EM-V5405SW 1200 Watts Microwave Oven Logo
93 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
tony denham
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
