Question about Dell Dimension 8400 power supply ** FREE ** (D8400SATA300W24PINB) Power Supply
I cannot detect any problem with the computer other than the power lights continues to blink amber and white. Help.
    Novelist:
  • 137 Answers
If the power light is blinking Amber or Yellow, your power supply is no good. You can purchase a new power supply either online at places like http://www.tigerdirect.com or you can take your whole computer into a store like bestbuy and ask them to show you power supplies that will work with your computer.
If you are unsure on how to replace your power supply, I would suggest taking it to someone that will install it properly.
There are also a lot of videos out there like this one:
http://video.about.com/pcsupport/powersupply.htm
That show you how to do it yourself. Just make sure all the power connections are connected or you might have devices that dont' work properly.
Have a great day.
Posted on Jan 23, 2010
Testimonial: "The answer to my question was thorough and very informative. Thanks."
6ya staff
SOURCE:
Blinking white amber light above power cord
The power supply is the issue, or the DC jack in the laptop has developed bad connections, or ram issue. Remove 1 stick of ram and power on, if no! remove second one, and replace the first, power up, if no! test the power supply for proper voltage, if okay! it is a DC jack or motherboard problem.
Mar 09, 2012 | HEWLETT-PACKARD Probook 4530S
Power light on inspiron alternates white/ amber. battery 100%
If the power light is blinking amber, it means the computer is receiving electrical power, but a device might be malfunctioning or incorrectly installed. You may have to remove and then reinstall the memory modules.
Nov 23, 2011 | Dell Inspiron 15R Laptop Computer (Intel...
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
Blinking amber light.I changed 2 motherboards out and still blinking amber. Changed the CMOS battery, same thing blinking amber. Swapped memory and removed all pci cards, same thing. The motherboard has a...
I'm not clear about the blinking amber light you are referring to. Is it on the computer or the monitor.
I checked Dell's web site for the service manual for this computer model, & found this document:
http://support.dell.com/support/edocs/systems/dim8300/sm/adtshoot.htm#1102195
If the blinking amber light is on the monitor, check the connection between it & the computer itself. Make sure the cable is not damaged & that it does not have any broken pins in the socket.
Dec 16, 2009 | Dell Dimension 8300 PC Desktop
Amber light blinking Compaq Presario Notebook
Pull out the battery and replace it again. Then power it on again. If the problem persists, you will need to have the motherboard, processor and RAM checked by appropriate technical personnel. Any of these could be responsible.
Sep 17, 2009 | Compaq Presario sr1111nx 2.53GHz Celeron...
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Computers & Internet Logo
233 people viewed this question
Ekse
Clive
Clive
Alun Cox
