Exercise & Fitness Logo
Posted on Jan 23, 2010
Treadmill cuts out after 10 seconds and gives an E1 message.
The treadmill powers up and runs for 10 seconds before it cuts out and gives an E1 error message. Any advice?
Anonymous
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Oct 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
91075
Points
78
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
1helpful
Treadmill triumph 400t has error E1
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
2helpful
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
sincerely. God bless you
1helpful
Treadmill works for 30 seconds and then stops saying E1
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
6helpful
2answers
After starting the treadmill 10 seconds later E1 apears on the display
Your problem is that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
9helpful
2answers
2helpful
Etiger treadmill starts then after 5 secs or so cuts out and E1 error signe appears on console
Your problem is probably that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
16helpful
3answers
Error message E1
hi there we have an E1 error after 7 seconds of operation??
Top Horizon Exercise & Fitness Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
