When this happens it can be caused from a couple of things; I would recommend that you hard shock the device. You can do this by removing the battery while the device is powered on, leave it out for a minute, then reinstall the battery, and power the handset up. If this does not resolve your issue, then you are looking at a more serious handset issue.
Your problem is caused by the communication foil between the LCD and the mainboard of the phone. This foil contains a number of circuits that makes data transfer possible. The one or more circuits do not communicate anymore, the phone displays odd images.
Hi,there are two kinds of white screen in phone, the first one is because of damage LCD (glass screen and the flex of the phone that connects the phone board to the screen board that makes the phone display might be the solution. ) , defective display driver (small chips that makes the display works) and the other one is corrupted software...in damage lcd the phone will detected by computer because its software is still working...so , the problem of your phone am sure is the second one , corrupted software....your phone needs to reprogram,and need to go to the model of the phones care center to fix you problem... i hope ,i will help you ,thanks for trusting fixya...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
The
I
If
fixed/replaced.
Try taking battery out with phone on. Leave Battery out for at least a
minute and put back in. If still white and phone is under a year old,
contact service provider. They usually have a one year warranty if phone
is under a year with no physical damage. If phone is a refurbished
phone you may only have 60 to 90 days of warranty.
If the phone will do other things like ring when called, or seem to respond when you press buttons, then the lcd is either bad or the connector is loose. But if the phone will not ring when called and doesn't seem to respond to pressing buttons, then there is something wrong with the phone itself. Always try taking out the battery if you haven't already.
