Use a small putty knife. Put the putty knife in between the front panel and the top about 3 inches in on the left and right side. You will be inserting it straight in toward the washer and this will release 2 clips and allow the panel to rock towards you. Note some pressure must be applied and will not always release easily. Once the panel rocks toward you there will be 2 clips on the bottom. Just pull off of the clips and you are done. To reassemble allign the panel with the bottom clips and push the top back in, again with a little pressure.
Thank you
Please rate this post
This
article shows step by step photo instructions on how to replace the
door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
