Try adjusting the tension. It sounds like the bobbin thread is too loose or the bobbin is not in correctly. Try taking the bobbin out and turning it around and putting it back. When you hold the bobbin in the fingers of your left hand and you pull the thread out with your right hand the bobbin should be turning clockwise. If the nesting persists, try ajusting the tension one way and then the other to see which seems to help. Hope this helps!
Yes, VERY frustrating! When this has happened to me it has always turned out to be a tiny bit of thread caught in the bobbin assembly. I've rethreaded and rethreaded but could only solve the problem by taking the bobbin assembly apart and finding and removing the caught thread. I use a bright flashlight to help find the caught threads.
Make sure to thread machine with the presser foot raised. Then make sure thread gets in between the tension discs and that you have the machine threaded correctly with the thread going up and into the take-up arm. tension should be set at 4-5.
Take out your bobbin case... there should be a small screw fixture on the side of the case...turn screw anti clockwise until you get the correct tension ... To test the bobbin thread tension...Remove the bobbin case keeping bobbin attached and hold it by suspending it by the thread...**** it once or twice, if the tension is correct the thread will unwind by about an inch or two. If it does not unwind at all...tension is too tight. If the tension is too loose it will drop too much. Goog Luck
Threading the bobbin - winding thread onto the bobbin.
Position the new empty bobbin onto the vertical bobbin rod next to the end wheel. Click the rod to the right to engage drive. Hold the outer end wheel with left hand, and rotate the inner wheel anticlockwise by about a 1/2 turn (it stops) this removes drive from the foot and needle mechanism.
From a spool of thread on the top, thread to a loop/post on the left on the top. Then back to the bobbin you want to wind. Thread through a hole from the inside-out. Hold the thread vertically above the bobbin while you depress the footswitch to start winding. Let go when it's turned a few times.
Move bobbin shaft left, and tighten end wheel after winding enough.
Fitting bobbin-
Move footplate towards you, insert bobbin in hole so that bobbin rotates anticlockwise when thread is pulled, then pull thread into the fine notch towards you. After this position thread away from you, and slide the footplate closed.
To start / load thread. Hold the end 3" of the thread through the needle behind the sewing foot. hand crank towards you to sew first stitch in air. This should retrieve the lower thread - which you can catch with a handy pair of scissors. Then pull both threads rearwards - ready to sew.
