Which specific model do you have? The menus may depend on your model. Are you using the original TV remote or a different remote? If you do not have the TV remote, try the buttons on the TV. Use the channel up/down buttons to navigate through the menu items and the volume up button to enter a sub-menu.
Try Menu and locate the Channel sub-menu. Then make sure that the antenna Air/Cable item is set correctly. Then the Channel Search option is on the next line. This is the method for the LCD2050. For the TTM2901L, you need the same Channel sub-menu but the channel search is called "Auto Program".
A number of other manuals for Polaroid TVs are available here:
http://www.polaroid-tv.com/polaroid-lcd-tv/manual/ .
I hope this helps. If you add a comment with your model number, I'll be glad to provide additional help. (Note: without the model, I can't be sure which tuners (NTSC - analog OTA or cable, ATSC - digital OTA, or QAM - digital cable) are in your TV. This may change whether you can receive any stations without the cable boxes.)
