After launching vaio recovery and selected restore c:drive, it shut down and start up, but then went to "welcome" screen. Don't know why it's like this. did restore c:drive before and it's not like this
have you checked the hard drive to see if its bad or has bad sectors? did you check the bios ? and what operating system is on your recovery disk?have you checked the hard drive to see if its bad or has bad sectors? did you check the bios ? and what operating system is on your recovery disk?
You can't post conmments that contain an email address.
4-The Vaio Recovery Wizard will launch. Follow the
instructions given as you advance through the wizard. When prompted,
confirm that you want to reset your Vaio to its original factory
settings.
5-Allow the computer about an hour to properly restore itself to factory settings.
The Computer comes with a recovery partition present in the hidden partition of the Hard Drive. You can use this Recovery Partition to restore the Computer to the factory status. The Recovery Partition can be accessed using the VAIO Recovery Center Software installed in the Computer or by pressing and holding the F10 Key while restarting the Computer. Below are the steps to access the Recovery Partition in the Computer and to perform the System Recovery in the Computer.
Using VAIO Recovery Center.
To access the VAIO Recovery Center, click Start, Help and Support and click the "Troubleshoot my VAIO" option. Then, in the opened window, under VAIO Recovery Center, click Launch VAIO Recovery Center. After that, in the VAIO Recovery Center, click "Restore C: Drive" option to restore the Computer to the factory defaults. (Selecting the Restore C: Drive will erase all the Data in the computer and restore the Computer to the factory defaults). Once you have selected the "Restore C: Drive" option, please click the "Start" button, then, please follow the onscreen instructions to complete the Recovery Process.
Using F10 Key at the Start-up.
Please restart the Computer, press and hold the F10 Key for 7 to 10 seconds. Then, at the Edit Boot Options screen, press the Enter Key. This will launch the VAIO Recovery Center. Then, you can select the Restore C: Drive and go with on screen instructions to complete the System Recovery.
Good Luck!
Please post back if you have any questions or require any further assistance.
If you are trying to restore the Computer to the factory settings, it is not required to have the Recovery Discs as you
can use the Recovery Partition which is present in the hidden partition
of the Hard Drive. To access the Recovery Partition, restart the
Computer, press and hold the F10 Key for 7 to 10 seconds. This will boot
the Computer to the Edit Boot Options screen. There, please press the
Enter Key.This will launch the VAIO Recovery Center. In the VAIO Recovery Center window, you can select the "Restore C: Drive" option to restore the Computer to the factory settings. (Selecting the "Restore C: Drive" option will erase all the Data in the Computer and restore to the factory defaults)
After selecting the Restore C: Drive, please follow the simple onscreen instructions to proceed with the System Recovery. The System Recovery process using the VAIO Recovery Center should fix all the Software issues in the Computer and restore the Computer to the factory defaults.
Good Luck!
Click the Start button, then click Help
and Support . NOTE: If the Help and Support link
is not available on the Start menu, re-enable
the link in the Taskbar and Start Menu
Properties window.
In the Windows Help and Support window, click Backup & Recovery .
Under Backup & Recovery , under VAIO Recovery Center , click Launch VAIO Recovery Center .
In the VAIO Recovery Center window, under Choose a program , click to select the desired
option:
It is strongly recommended that recovery discs be
created to help restore files if the operating system will not start.
Recovery discs are bootable and can be used to perform a recovery on a
properly functioning hard drive.
The Windows
Backup and Restore option opens the Backup
and Restore Center provided with the Windows Vista® operating
system. This provides the ability to save information from the hard
drive, such as personal data files, and restore previously backed up
data.
Computer problems related to hardware can be diagnosed
using the VAIO Hardware Diagnostics option.
One or more drivers or factory-installed applications may be
reinstalled with the Reinstall Programs or Drivers
option.
The entire (C:) drive can be restored to its
original, factory-installed condition by selecting Restore
C: Drive .
Choosing Restore
Complete System will restore the entire (C:) drive, while
removing or restoring the Recovery Drive partition. Modifying the size
of the hard drive partitions is also an option with this type of
recovery. This option requires you to insert Recovery DVDs created using
the Create Recovery Discs option.
To
remove all data from the hard drive, including the operating system,
all programs and personal data, choose the Wipe
and Erase Data option. This option is provided for the
convenience of advanced users who want to install a different operating
system, and who want to ensure all data has been removed from the hard
drive first. All other users are strongly urged to avoid selecting this
option.
The VGN-FW370J/H Computer is shipped with Recovery Partition which is present in the hidden partition of the Hard Drive.
If you do not have the Recovery Discs and the VAIO Recovery Center is not working, a recovery of the (C:) drive can be performed by accessing the Recovery Partition. (If the Recovery Partition is not accessible by pressing the F10 Key while restarting the Computer, the only option is to purchase the Recovery Discs and perform the System Recovery.)
Please follow the below steps to access the Recovery Partition and restore the Computer to the factory default.
Note: Restoring the Computer to the factory settings will erase all the Data on the Hard Drive and restore it to the factory condition.
Restart the Computer, press and hold the F10 Key.
If and Edit Boot Options Screen appears, press the Enter Key.
This will launch the VAIO Recovery Center window.
In the VAIO Recovery Center window, please select the Restore C: Drive option.
Next to the "Restore C: Drive", please click the "Start" button.
Under Before Restore C: Drive , ensure the Skip option is selected, and click the Next button.
Under WARNING: This program deletes all files on the C: drive , click to select the I understand box.
Then, click the Start button.
After the bundled applications are installed, click the Finish button.
The computer will restart and the operating system setup wizard will
begin. Follow the on-screen instructions to complete the setup wizard.
This should restore the Computer to the factory defaults.
The Windows Memory Diagnostic Tool can determine if any problems being experienced are caused by issues with the computer's memory.
The option to open a Command Prompt can be used by advanced users and technical support personnel to perform troubleshooting on the hard drive or the operating system.
Clicking VAIO Recovery Center will launch VAIO Recovery Center from the Recovery Disc.
You will have to use a Windows DVD and boot on it, try a "Repair" install, If this doesn't "Take" then you will have to do a complete reinstall.
sony VAIO computers uses a hidden partition one the harddrive which is VAIO recovery center
restart the computer then press F10 key repeatedly for 5-7secs when you see the vaio logo on the screen, until you see loading files or edit boot options
if you get the edit boot options screen, press enter
it will load the Vaio recovery center
select Restore c: drive
disconnect all external devices before starting the recovery, also turn off the wireless switch if there is
doing the recovery may take up to 45mins or 1 hour with random restarts. it will install the os, driver and programs that came with the computer
I found these instructions for you on the Sony support site.
Solution
IMPORTANT:
Before performing a recovery, go to the Sony® eSupport Web site at http://esupport.sony.com and
check your model-specific support page. Look for software and driver
updates or check for knowledge base solutions that may help you solve
your computer's issue.
This model does not require Recovery CDs. Recovery data is included on a special partition of the hard drive.
Do not interrupt the power during the recovery process.
Before
performing a recovery, disconnect any external devices not supplied
with the computer such as printers, network cables, cameras, or
external storage devices, like hard drives or flash drives.
Customers
who purchased the Symantec® Norton Internet Security® 2007 software
from the Sony Style® store with their computer must create a Norton Account to save their product key prior to a system recovery or the software cannot be reinstalled.
Click the Start button, then click Help and Support . NOTE: If the Help and Support link is not available on the Start menu, re-enable the link in the Taskbar and Start Menu Properties window.
In the VAIO Recovery Center window, under Choose a program , click to select the desired option:
It
is strongly recommended that recovery discs be created to help restore
files if the operating system will not start. Recovery discs are
bootable and can be used to perform a recovery on a properly
The Windows Backup and Restore option opens the Backup and Restore Center provided
with the Microsoft® Windows Vista™ operating system. This provides the
ability to save information from the hard drive, such as personal data
files, and restore previously backed up data.
Computer problems related to hardware can be diagnosed using the VAIO Hardware Diagnostics option.
One or more drivers or factory-installed applications may be reinstalled with the Reinstall Programs or Drivers option.
The entire (C:) drive can be restored to its original, factory-installed condition by selecting Restore C: Drive .
Choosing Restore Complete System will
restore the entire (C:) drive, while removing or restoring the Recovery
Drive partition. Modifying the size of the hard drive partitions is
also an option with this type of recovery. This option requires you to
insert Recovery DVDs created using the Create Recovery Discs option.
To remove all data from the hard drive, including the operating system, all programs and personal data, choose the Wipe and Erase Data option.
This option is provided for the convenience of advanced users who want
to install a different operating system, and who want to ensure all
data has been removed from the hard drive first. All other users are
strongly urged to avoid selecting this option.
